new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 02:12PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 02:13PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 02:34PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 03:14PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 03:46PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 04:04PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 04:22PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 06:19PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 09:06PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 11:19PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 11:27PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 27, 2015 11:32PM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 28, 2015 03:36AM |
lunarkingdom
here is the info from the side of the stepper motor:
17H53413L19P1-X
1.8 deg 1.3A
1409290805
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 28, 2015 09:24AM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 28, 2015 09:26AM |
lunarkingdom
thanks dc42, just pulled the trigger on 5 of the 17HS19-1684S (I like spares) thanks for the advice!!
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 28, 2015 09:49AM |
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 28, 2015 10:26AM |
dc42
lunarkingdom
Did you really need 5, if it is only the Y axis that is giving the problem? You could change just that motor.
btw when you get your new drivers, be aware that a given voltage on the pot wiper will give you more current with the ice blue stepsticks than with your old ones - twice as much I believe.
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 29, 2015 10:34PM |
the_digital_dentist
You can try playing with the acceleration and jerk settings, but you may have to slow things down quite a bit to get it to print reliably. I use NEMA-23 motors in all axes. A massive bed running at "normal" speeds/accelerations requires a lot more torque than you can get from most NEMA-17 motors. You can run a lot of NEMA-23 motors using the RAMPS board- I was using it that way for 2 years without problems (except for vibration).
Re: new build and my heat bed is heavy, thin nema 17 looses track of where it is on fast moves April 30, 2015 07:48AM |
