Hotbed flatness, voodoo or scientific method? May 06, 2015 10:01AM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 11:05AM |
Are you talking about being flat, or being level? There's a difference and it's the latter that's usually the bigger issue.Quote
lunarkingdom
They both have less than 1 thousandth of an inch in flatness, this is amazing to me, especially since I have been struggling to figure out how to achieve this very same thing.
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 12:00PM |
Interesting. It's certainly being level that is more talked about, but being level without being flat seems both ill defined and not particularly useful. My MK2 bed is decidedly non-flat and I've been worrying about how I'm going to deal with that. I was wondering if the MK3s are typically flatter. If so, that might be the easiest way forward. At least standard 200mm sq beds are not particularly expensive.Quote
cdru
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 12:36PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 01:25PM |
cdru
lunarkingdom
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 02:52PM |
.010mm or .010in? Huge difference.Quote
lunarkingdom
...my current design is at least .010 higher on the outer 50% while the center is lower.
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 03:17PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 03:26PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 04:43PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 05:56PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 06:19PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 06:33PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 06:41PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 06:48PM |
the_digital_dentist
Cast aluminum tooling plate comes milled flat. It doesn't have the same crystal structure as extruded plate so it doesn't warp appreciably when heated
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 09:40PM |
JamesK
That 1/4" plate sounds nice, but it will add a lot of mass to a moving print bed design. The simplicity of the Prusa layout is very appealing, but I keep finding myself drawn to a core-xy layout with the bed motion confined to Z. Maybe next time.
I was wondering about epoxying some pieces of aluminum U channel to the heat bed to increase flatness and rigidity, but I have my doubts about how the combination would cope with thermal expansion/contraction. My current plan is to have the heat bed track side up with a thin aluminum sheet to act as a heat spreader and glass on top as the print surface. I guess with that layout I could tolerate some warp in the heat bed itself as long as the aluminum and glass stayed fairly flat and there was still adequate heat transfer. Maybe I can bond the aluminum to the bed with a thermally conductive glue?
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 10:27PM |
Yes, I'm trying to save money by using materials that I either have to hand or can source cheaply. I guess you're in the US where you have the great fortune of a multitude of suppliers and frequently free shipping. A quick check of my usual sources, the best I can do for 12x12x.25" cast aluminum is $103 shipped. That's USD which translates to $125 CAD. To put that in perspective my total spend so far is less than $300 US, and I believe I have everything I need.Quote
the_digital_dentist
What are you trying to achieve by combining all this stuff? Putting multiple thin layers of different materials together, each with different expansion and warp behaviors over temperature, is a sure fire way to never get the thing flat. An aluminum plate is simple, inexpensive, and works without any screwing around. My 12" x 12.5" x 1/4" plate cost about $30. Are you going to save $5 and 100 gm by using thinner sheet and a piece of glass, and some mystery adhesive?
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 10:30PM |
Re: Hotbed flatness, voodoo or scientific method? May 06, 2015 10:33PM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 12:44AM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 12:56AM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 01:50AM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 04:55AM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 08:33AM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 08:48AM |
Even better would be if the insulator had the same coefficient of expansion as the glass.
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 09:10AM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 09:36AM |
So what you're saying is that using a pink granite surface plate with a tolerance of .000050" might be overkill with my printer made from threaded rod and cheap Chinese linear bearings on drill rod with a hobbed bolt extruder made with a tap with a hand drill?Quote
the_digital_dentist
build a solid printer that's able to maintain the level setting throughout the range of motion of the X and Y axes
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 10:11AM |
Re: Hotbed flatness, voodoo or scientific method? May 07, 2015 10:13AM |
cdru
the_digital_dentist
My .02, just use a piece of plate glass and maybe a piece of tool plate. Buy a decent quality piece and spend your time and money elsewhere. If we needed .0001" tolerance, we wouldn't be in a RepRap forum building printers out of threaded rods, motors ripped out of discarded electronics, and old ATX power supplies...
