Using ramps with bigger stepper drivers? May 09, 2015 07:54AM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 08:25AM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 09:23AM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 11:42AM |
the_digital_dentist
I'm using two of these: [www.sainsmart.com] in my printer, with 32V power supplies. These drivers can handle up to 50V supplies.
The inputs are optoisolated, so you can safely connect to the RAMPS board without fear of destroying it. You need to pull the step, direction, and enable signals and a ground connection from the stepper module sockets.
Re: Using ramps with bigger stepper drivers? May 09, 2015 11:55AM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 12:46PM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 01:10PM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 04:58PM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 05:11PM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 05:27PM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 06:08PM |
Re: Using ramps with bigger stepper drivers? May 09, 2015 09:40PM |
Re: Using ramps with bigger stepper drivers? May 10, 2015 03:24AM |
Re: Using ramps with bigger stepper drivers? May 10, 2015 04:40AM |
Re: Using ramps with bigger stepper drivers? May 10, 2015 06:55AM |
JamesK
They have higher resistance coils, so take a greater voltage to drive the 1A. Work is VI, so the laws of physics remain unbroken. I'd expect the DRV8825 to drive them fine, but you'd probably need 24 to 36V to get good step rates and that would present a challenge if you host the drivers on a RAMPS board. a good quality RAMPS will have 35V capacitors, so it should be possible to run it to 24V. Watch out for budget boards that have 16V capacitors. There are some issues to running RAMPS at >12V, but there's info here [rigidtalk.com]
Re: Using ramps with bigger stepper drivers? May 10, 2015 07:14AM |
Olaf
you´d use an adapterboard between driver and RAMPS
Re: Using ramps with bigger stepper drivers? May 10, 2015 11:39AM |
Re: Using ramps with bigger stepper drivers? May 11, 2015 01:45AM |
Re: Using ramps with bigger stepper drivers? May 11, 2015 02:09AM |
Re: Using ramps with bigger stepper drivers? May 11, 2015 03:04AM |
