Printer only works in dry mode May 13, 2015 12:56PM |
; generated by Slic3r 1.2.6 on 2015-05-13 at 19:37:19 ; external perimeters extrusion width = 0.40mm ; perimeters extrusion width = 0.40mm ; infill extrusion width = 0.40mm ; solid infill extrusion width = 0.40mm ; top infill extrusion width = 0.40mm M107 M190 S90 ; set bed temperature M104 S210 ; set temperature G28 ; home all axes G1 F100 X1 Y1 Z0.2 ;Lift nozzle G92 E0 G1 F100 E2 G4 P3000 M109 S210 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 G1 Z0.300 F9000.000 G1 E-2.00000 F1800.00000 G92 E0 G1 X103.708 Y34.147 F9000.000 G1 E2.00000 F1800.00000 G1 X163.292 Y34.147 E2.84962 F900.000
Re: Printer only works in dry mode May 13, 2015 04:54PM |
Re: Printer only works in dry mode May 14, 2015 05:30AM |
Re: Printer only works in dry mode May 14, 2015 07:41AM |
Re: Printer only works in dry mode May 14, 2015 05:23PM |
Re: Printer only works in dry mode May 15, 2015 02:58AM |
