OctoPrint vs PrintToPeer vs PrinterOS May 24, 2015 02:55PM |
Re: OctoPrint vs PrintToPeer vs PrinterOS May 24, 2015 03:22PM |
Re: OctoPrint vs PrintToPeer vs PrinterOS May 26, 2015 08:37AM |
I can confirm that OctoPrint can do all of those things. While OctoPrint can slice using the Cura engine (and possibly others?) if you like to tweak slicing settings for individual prints I think you'll be disappointed since the configuration is file-based. If you set it and forget it with slicer settings, then it might work well although slicing speed is going to be a slower than most modern computers.Quote
jessicabrenner
Does anyone know if any of these CANNOT do this? OctoPrint says it can.
With OctoPrint itself, it only supports one camera view out of the box. However the camera view really is bolted on and is actually just displaying images served up from a separate web cam service. In theory you could spin up multiple processes for multiple cameras. You'd need to modify the source code if you wanted to switch between cameras, or you could just create your own webpage outside of OctoPrint that showed just the camera views. Combining images to form a time lapse also would only be for a single view out of the box but again you could hook up something outside of OctoPrint if you really wanted to.Quote
Do any support multiple camera views?
Yes, although they would need to be on your network or you'd need to port forward the necessary ports through your firewall to give her access.Quote
Does anyone know for any of these if I'd be able to send a link to a friend to allow her to view the print?
Re: OctoPrint vs PrintToPeer vs PrinterOS May 28, 2015 02:16AM |
Re: OctoPrint vs PrintToPeer vs PrinterOS May 28, 2015 08:53AM |
