Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 01, 2015 09:48AM |
Re: Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 01, 2015 11:44AM |
Re: Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 02, 2015 07:02PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 02, 2015 10:44PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 02, 2015 11:08PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 03:13AM |
Re: Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 03:49AM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 12:25PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 12:36PM |
XYZM
Vref is from the adjustment pot, and black on ground..
Motor current rating is 1.5A Model: 42SHD0217-24B
There is a screw on my power suppl, near the connections.., any idea what this adjusts?
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 12:37PM |
XYZM
I would have to check the mains. I assume I put the multimeter on ground and live, or should I test the end that goes to the board...
XYZM
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 02:01PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 02:15PM |
XYZM
Oh yes I live in the US, I am set to 220V
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 02:20PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 02:25PM |
XYZM
ahhh
On the side of the power supply it says
"110-120v 50 Hz"
"220-240v 60Hz"
I know we are on 60hz so I left it as it was.
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 02:43PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 02:48PM |
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 05:50PM |
Then you need to disconnect the PSU from the mains, wait a while (I suggest at least 10 minutes), then move the switch to the 110V position.
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on June 03, 2015 06:08PM |
tadawson
Or just switch it immediately. There is absolutely nothing in a switching supply to merit a wait, and the 12v will be gone in 5 to 10 seconds if connected to the printer anyhow. In this case, since no output wiring is being worked on, that is irrelevant as well . . .
- Tim
Re: Video Update! Power Supply Issue? Motors only studder when Extruder and Heat bed are on July 17, 2015 05:15AM |
