Filament drying technique June 03, 2015 12:37PM |
Re: Filament drying technique June 03, 2015 01:21PM |
Re: Filament drying technique June 03, 2015 01:45PM |
Re: Filament drying technique June 03, 2015 01:56PM |
Re: Filament drying technique June 03, 2015 02:01PM |
Re: Filament drying technique June 03, 2015 03:01PM |
Re: Filament drying technique June 03, 2015 03:16PM |
Re: Filament drying technique June 03, 2015 03:44PM |
Re: Filament drying technique June 03, 2015 05:29PM |
Re: Filament drying technique June 03, 2015 05:57PM |
Re: Filament drying technique June 03, 2015 06:04PM |
Re: Filament drying technique June 03, 2015 06:23PM |
Koko76
In my experience the words cheap and high precision (along with the equally important repeatability) are not found in the same sentence. To me personally if something is worth measuring, it's worth what the right tool to measure it costs. Henry Ford has a great saying about this. But I think it would be simpler to cut a bunch of several gram samples enough to print some test object, pull one every x minutes and test in the printer.
Re: Filament drying technique June 03, 2015 06:39PM |
Re: Filament drying technique June 03, 2015 07:37PM |
Re: Filament drying technique June 04, 2015 01:23AM |
Re: Filament drying technique June 04, 2015 06:29AM |
Re: Filament drying technique June 04, 2015 07:01AM |
Re: Filament drying technique June 04, 2015 11:37AM |
Re: Filament drying technique September 15, 2016 06:26PM |
Re: Filament drying technique September 15, 2016 08:57PM |
Re: Filament drying technique September 16, 2016 09:06AM |
Re: Filament drying technique September 16, 2016 06:56PM |
Re: Filament drying technique September 17, 2016 07:16AM |
Re: Filament drying technique September 17, 2016 09:48AM |
dtwrv6
Yes. It is.
Re: Filament drying technique September 17, 2016 03:10PM |
Re: Filament drying technique September 19, 2016 08:26AM |
Tinchus
I had problem with humedity. After a lot of research and thinking, I came to this: [forums.reprap.org] (see in the middle of post)
My dryer lets me dry many rolls at the time and also print with the roll inside, so it is always dry.
Regarding times, I had problem with hig temepratures: for some reason some filaments change something in their composition. Also, the roll itself sometimed deforms. Better results for any kind of filaments: 4/5 hs at 40 degrees. The gives me a really nice dry filaments,
Hope it helps
