Ways to extend wiring? June 03, 2015 04:50PM |
Anonymous User
Re: Ways to extend wiring? June 03, 2015 07:11PM |
Re: Ways to extend wiring? June 03, 2015 10:19PM |
Re: Ways to extend wiring? June 03, 2015 10:23PM |
Re: Ways to extend wiring? June 04, 2015 01:25AM |
Re: Ways to extend wiring? June 04, 2015 02:40AM |
dave³
I need to extend the wiring from my nema17, e3dv6 and motor fans
Anonymous User
Re: Ways to extend wiring? June 04, 2015 03:03AM |
Anonymous User
Re: Ways to extend wiring? June 04, 2015 03:07AM |
o_lampe
Did you say, you want to extent the cables for the E3Dv6? Than you might look for a pair of thicker wire than 22AWG or the hotend will stay too"cold".
I´m not familiar with these AWG sizes, probably some US-reprapper can tell?
If you have a smart-LCD, don´t extend these cables. They already work like antennas and I had scrambled screens more than once.
-Olaf
Re: Ways to extend wiring? June 04, 2015 04:59AM |
Re: Ways to extend wiring? June 04, 2015 08:42AM |
Anonymous User
Re: Ways to extend wiring? June 04, 2015 09:02AM |
davedavedave
thanks a million for the links and the advice. its gonna help a lot!
i found this wire, is this better? i plan on buying the 22 gauge from the link and was wondering if this would also be a good buy
are these the same as the ones you linked me too? only a thicker wire i am assuming.
6 color 18 gauge 100ft
The thicker the wires are, the less flexibility they will have. I can't tell what kind of quality the wires are without looking at a sample, though. The ratings might be your best guide. I would be careful that it is all copper and not copper clad aluminium, though.
heya 3dkarma, thanks for letting me know about that, i had no clue. im not sure if i will extend it BUT to be on the safe side i might buy a kit like this, that is, if the wires are the correct type for the hot end. let me know what you think about the wires in this link below. thanks!
14 gauge 100 ft 6 color wire
Re: Ways to extend wiring? June 04, 2015 03:05PM |
o_lampe
Flexible Stranded Copper Clad Aluminum
That doesn´t sound good for my foreign ears.
-Olaf
Re: Ways to extend wiring? June 04, 2015 03:08PM |
Re: Ways to extend wiring? June 04, 2015 03:20PM |
Re: Ways to extend wiring? June 04, 2015 03:52PM |
o_lampe
3Dkarma
He already answered it, I´d say...
Re: Ways to extend wiring? June 04, 2015 04:50PM |
22 AWG is perfectly fine for a hot end as it's rated, at least by NEC (National Electric Code), for 7 amps for chassis wiring. If you're drawing 7+ amps for your hot end you have the largest hot end heater I've ever heard of.Quote
o_lampe
Re: Ways to extend wiring? June 04, 2015 04:52PM |
Re: Ways to extend wiring? June 04, 2015 06:03PM |
cdru
o_lampe
Anonymous User
Re: Ways to extend wiring? June 04, 2015 07:19PM |
davedavedave
oh so whats the downside to using lower gauges on hotends that require 7+ amps? is it not able to reach temps fast enough? or will they not heat up at all? thanks.
Re: Ways to extend wiring? June 04, 2015 07:25PM |
davedavedave
quick question about gauges. so I know there are many different wire gauges but what I want to know is what are the downsides to using a 14 gauge wire on something like a nema17 or cooling fans? so pretty much, are there negatives to using say, 12 or 14 gauge wires on something that doesn't require such a big wire? thanks
Re: Ways to extend wiring? June 04, 2015 08:07PM |
Re: Ways to extend wiring? June 04, 2015 08:32PM |
Re: Ways to extend wiring? June 05, 2015 03:14AM |
Re: Ways to extend wiring? June 05, 2015 03:15PM |
