confused smileyHelp with hotend
Posted by macsoft
June 04, 2015 07:28AM
I've recently bought a E3D hotend.
I'm still on the number changing game to get it right.. it seas I need to set at much higher temperatures to get the same results I'm used to with PLA, but that is not the reason for this post.
I have a different problem with it:
When I set a target temperature, the firmware raises temperature until it is almost there and shuts off 4 or 5 degrees before, expecting it to go up on its on the last degrees.
Problem is, the minute the heater shuts off, temperature only raises a couple of degrees before coming down, so it NEVER gets to the target temperature.
I have to manually lower target temperature for it to start printing.
Where I can change the shut off setting so It shuts off closer to the target temperature?
A G ccode would be even best.
I've been looking on G570 but it seams it is a diferent type of timeout.
Help?
thanks.
Re: confused smileyHelp with hotend
June 04, 2015 07:49AM
Hi Mac,
What value do you have in your firmware for the thermistor?
Regards
NFireLabs - The World First Modular 3D Printer - At An Affordable Price!
June 04, 2015 08:18AM
The reason for the temp cutoff too early, is the PID setting in firmware
I donĀ“t know, how to fix this. Maybe there is an autotune option?
-Olaf
June 04, 2015 09:26AM
You haven't told us what electronics and firmware you are running, which makes it difficult to help you.
