Inconsistent extruder feed, jams - tried new hotend with no luck June 19, 2015 05:45PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 19, 2015 06:57PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 19, 2015 07:00PM |
the_digital_dentist
The hot end can only melt plastic so fast. If you exceed its capability, the temperature will drop and you'll be trying to push almost solid filament out of the nozzle. What sort of power is the hot end heater rated for?
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 19, 2015 07:03PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 19, 2015 07:05PM |
the_digital_dentist
Is that the print speed or the filament feed speed?
if you change the hot end you definitely need to run the PID autotune before trying to print.
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 20, 2015 10:33AM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 20, 2015 11:04AM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 20, 2015 01:27PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 20, 2015 01:43PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 20, 2015 01:44PM |
the_digital_dentist
What are you measuring exactly?
If you tell the firmware to extrude 10mm of filament, that means 10mm on the input side of the extruder.
You'll notice that the extruder drools even when it isn't extruding filament- that's because the filament in the hot end expands as it melts and pushes some liquid out the nozzle. If you're measuring the output at the nozzle it will likely include some drool which will vary depending of how quickly you measure.
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 20, 2015 02:26PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 20, 2015 02:33PM |
the_digital_dentist
Problems with poor quality for thin layers may be due to back pressure on the extruder. That indicates you're running at the limit of the extruder's torque, which would also explain slip at higher extrusion speeds. That means either a bigger motor or higher current/driver are needed, or there is something wrong with the driver you're using.
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 10:01AM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 10:18AM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 10:25AM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 10:33AM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 10:44AM |
the_digital_dentist
It's more likely a problem with the cable to the motor than the motor itself. Extruder carriage cables flex a lot when the printer runs. It is easy for the cable to become intermittent due to excessive flexure, especially if you have a cable chain with a small radius of curvature on the extruder carriage. Your problem could be caused by an intermittent motor wire or heater wire. You won't be able to tell by looking at the wires- the metal conductor may have broken inside its insulation.
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 11:20AM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 01:09PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 06:40PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 07:43PM |
geemoto
My cables are in a spiral wrap coming down from the top, so there isn't too much tension on them. A lot of things to consider I guess. My prints aren't nearly as badly as the print you posted, it seems more like 1 or 2 layers are missing in extrusion.
I feel it has something to do with the motor/stepper driver/hobbed bolt. When I remove the hotend, it is quite consistent in #steps/mm, but when I put the hotend back on I require significantly more steps/mm. This is quite worrisome, indicating the pressure somehow affects the #steps/mm. I'm not sure if the load on the stepper is causing it to miss steps, or if the load on the hobbed bolt causes it to slip on the filament
Is it likely that using knockoff RAMPS/Arduinos could be causing problems?
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 07:58PM |
tadawson
Not that likely . . . more likely is that either the current is set wrong, or the extruder does not have enough pressure to bite the filament (this can happen if the bearing backing the drive fails as well). How warm does your extruder motor get after running for a while?
- Tim
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 08:05PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 08:07PM |
L4nce0
All I can say is when I'm really trying to print fast (200 mm/s) (no idea what that equates to with the hot end) with PLA I'll crank it to 220-240. I mean you're trying to spit the plastic out at almost twice the speed. It has microseconds in contact with the hot end. I'm looking at getting an all metal hot end so I can hit 260+ with ABS for fast speeds.
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 09:05PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 09:10PM |
JamesK
That looks like a very tight bend in the filament - is it like that when you print? Can you straighten the path out and make sure the filament is always free to feed into the extruder during a print?
JamesK
And, if the extruder stepper motor is getting hot with a fan on it, there's a chance that the driver is reaching thermal shutdown. Do you have a way of measuring the temperature of the driver? Have you checked the Vref on the driver to see what the current is set to?
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 09:22PM |
Ah, good - sorry for the dumb question!Quote
geemoto
Nope, it was just like that for the picture to get it out of the way.
A4988 or DRV8825? That would be roughly 2.5A or 2A - definitely too much for an A4988 and possibly enough to shutdown the 8825 depending on how well cooled it is. Unless you are using a different stepper driver with a different sense resistor value?Quote
geemoto
It's 1.02V
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 09:24PM |
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 09:28PM |
JamesK
...and possibly enough to shutdown the 8825 depending on how well cooled it is. Unless you are using a different stepper driver with a different sense resistor value?
Re: Inconsistent extruder feed, jams - tried new hotend with no luck June 21, 2015 09:40PM |
