Marin version Graphic LCD change filament July 12, 2015 04:22PM |
Re: Marin version Graphic LCD change filament July 13, 2015 01:36AM |
Connecting... start Printer is now online. echo:Marlin1.0.0 echo: Last Updated: Jul 13 2015 07:26:49 | Author: (none, default config) Compiled: Jul 13 2015 echo: Free Memory: 3693 PlannerBufferBytes: 1232
Re: Marin version Graphic LCD change filament July 13, 2015 02:27AM |
o_lampe
Works well, if you don´t move the extruder by hand while you change filament.[/color]
plan_buffer_line(lastpos[X_AXIS], lastpos[Y_AXIS], target[Z_AXIS], target[E_AXIS], feedrate/60, active_extruder); //move xy back plan_buffer_line(lastpos[X_AXIS], lastpos[Y_AXIS], lastpos[Z_AXIS], target[E_AXIS], feedrate/60, active_extruder); //move z back plan_buffer_line(lastpos[X_AXIS], lastpos[Y_AXIS], lastpos[Z_AXIS], lastpos[E_AXIS], feedrate/60, active_extruder); //final untretract
HOMEAXIS(X); HOMEAXIS(Y); plan_buffer_line(lastpos[X_AXIS], lastpos[Y_AXIS], target[Z_AXIS], target[E_AXIS], feedrate/60, active_extruder); //move xy back plan_buffer_line(lastpos[X_AXIS], lastpos[Y_AXIS], lastpos[Z_AXIS], target[E_AXIS], feedrate/60, active_extruder); //move z back plan_buffer_line(lastpos[X_AXIS], lastpos[Y_AXIS], lastpos[Z_AXIS], lastpos[E_AXIS], feedrate/60, active_extruder); //final untretract
Re: Marin version Graphic LCD change filament July 13, 2015 02:58AM |
OK, so because I will almost certainly move the head when changing the filament, the print is destined to fail.
