Marlin parse SD file update LCD July 14, 2015 12:51PM |
case 23: //M23 - Select file starpos = (strchr(strchr_pointer + 4,'*')); if(starpos!=NULL) *(starpos)='\0'; // my note : add code to count the Z axis commands ( layers ) in the file and the G1 print lines in the file #ifdef SDSUPPORT #ifdef ShowLayerCountAndEstTime CountLinesAndLayers = true; #endif //layer counter #endif //SDSUPPORT break;
ClearToSend();
if(CountLinesAndLayers == true){ // read the SD file and count the lines and layers CountLinesAndLayers = false; // update the LCD here and display a message to say "Reading SD file .." PrintLinesTotal = 0; LayerCountTotal = 0; card.openFile(strchr_pointer + 4,true); chPos = 0; // pointer for position of next char in buffer array while(!card.eof()){ int16_t n=card.get(); serial_char = (char)n; if(chPos < 59) SDbuffer[chPos] = serial_char; if(chPos >= 1 && chPos < 99){ // chPos = 99 is set when X or Z is found, so used to skip the check until the next end of line char // reset the counters if custom gcode comment ';SLC' that was added in Slic3r at the start of the print job, after the nozzle was positioned if(chPos == 3){ if(SDbuffer[0] == ';' && SDbuffer[1] == 'S' && SDbuffer[2] == 'L' && SDbuffer[3] == 'C'){ // check if the buffer line starts with ';SLC' ( SLC = Start Layer Count ) LayersToIgnore = LayerCountTotal; MYSERIAL.print("Set LayersToIgnore = "); MYSERIAL.println(LayersToIgnore); PrintLinesTotal=0; LayerCountTotal=0; } } if(SDbuffer[0] == 'G' && SDbuffer[1] == '1'){ // check if the buffer line starts with 'G1' if(serial_char == 'X'){ PrintLinesTotal++; chPos = 99; } if(serial_char == 'Z'){ LayerCountTotal++; MYSERIAL.print("LayerCountTotal = "); MYSERIAL.println(LayerCountTotal); chPos = 99; } } } chPos++; if(serial_char == '\n'){ // if the character read from the SD card is a line ending chPos = 0; // reset the position for the next character in the buffer. Set to 0 = empty the buffer. } } card.closefile(); delay(200); card.openFile(strchr_pointer + 4,true); //this is in M23 - Select file } // end of : if(CountLinesAndLayers = true)
Re: Marlin parse SD file update LCD July 15, 2015 03:33PM |
