8mm linear shaft July 19, 2015 11:30PM |
Re: 8mm linear shaft July 20, 2015 12:08AM |
Re: 8mm linear shaft July 20, 2015 02:12AM |
Re: 8mm linear shaft July 20, 2015 09:26AM |
Re: 8mm linear shaft July 20, 2015 09:33AM |
Re: 8mm linear shaft July 20, 2015 11:09AM |
Re: 8mm linear shaft July 29, 2015 02:14PM |
Re: 8mm linear shaft July 29, 2015 03:11PM |
Re: 8mm linear shaft July 29, 2015 05:17PM |
Re: 8mm linear shaft July 31, 2015 02:45AM |
The least expensive way to a decent, small band saw that has the capablitiy to cut metal properly is a mount for a portable bandsaw. The portaband can be had as cheap as a hundred bucks or so at Harbor Freight [www.harborfreight.com] with the stand another $60 or so on the low end vise mounted stand. There are other stands for other saws [www.swagoffroad.com] . If you have the funds one of the Milwaukee saws on a factory refurb sale [www.cpomilwaukee.com] and the v4 of the SWAG stand and you've got an excellent quality, small bandsaw suitable for most materials with the proper blades for under $400.Quote
davedavedave
So for the chop saw, the blades can cut steel and the cobalt is good for drilling aluminum then. Also i wanted to buy a bandsaw and looked around but couldnt find any that cut metal for under 200. I know they can be altered but usually its a lot of work or very tricky at the least
Re: 8mm linear shaft July 31, 2015 09:57AM |
Re: 8mm linear shaft July 31, 2015 10:53PM |
madmike8
I have used a dremel with a cutoff wheel. clamp the dremel down and then rotate the rod on the cutting wheel.
Re: 8mm linear shaft July 31, 2015 10:56PM |
Re: 8mm linear shaft August 01, 2015 11:18PM |
davedavedave
@Vegasloki
Hey man thanks for the info, much appreciated, I will def buy a good bandsaw once I get the funds. its necessary for me to have my own tools now. also, for the link you posted above with the 3/32 chop saw blades, just to make sure. do they cut the 8 mil steel shafts? or are those for the aluminum? if theyre for steel then that's what im going to get per your recommendation. if you do know about blades that can deal with Al then send me a link if you have the time. thanks again.
-Dave
Re: 8mm linear shaft August 03, 2015 01:05AM |
