MAX endtop setting of H-bot July 29, 2015 06:14AM |
Re: MAX endtop setting of H-bot July 29, 2015 07:35PM |
RepRot
I have all the endstops enabled with my Openbeam coreXY.
From what I can remember....
Apart from the settings in Configuration.h e.g.
Line 337 - have the following inactive e.g //#define DISABLE_MAX_ENDSTOPS
Line 338 - have the following inactive e.g //#define DISABLE_MAX_ENDSTOPS
Line 375 - have the following set e.g #define X MAX_POS 200
Line 376 - have the following set e.g #define X MIN_POS 200
Line 377 - have the following set e.g #define Y MAX_POS 200
Line 378 - have the following set e.g #define Y MIN_POS 200
Line 379 - have the following set e.g #define Z MAX_POS 200
Line 380 - have the following set e.g #define Y MIN_POS 200
You need to check in Configuration_adv.h
Line 90 - have the following inactive e.g.. //#define ENDSTOP_ONLY_FOR_HOMING
Line 312 - you may wish to have this active if printing from SD cards e.g. #define ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLE (Need to enable from LCD to stop printing if wanted for every time you go to print something).
Re: MAX endtop setting of H-bot July 29, 2015 08:44PM |
Re: MAX endtop setting of H-bot July 29, 2015 08:47PM |
Re: MAX endtop setting of H-bot July 29, 2015 09:23PM |
Re: MAX endtop setting of H-bot July 29, 2015 09:50PM |
Re: MAX endtop setting of H-bot July 29, 2015 10:04PM |
Re: MAX endtop setting of H-bot July 29, 2015 11:10PM |
Re: MAX endtop setting of H-bot July 29, 2015 11:47PM |
Re: MAX endtop setting of H-bot July 29, 2015 11:52PM |
Re: MAX endtop setting of H-bot July 30, 2015 01:39AM |
1nxtmonster
Wow, of course, how could I have forgotten. You need the development version for it to work. Download it from the marlin github.
Re: MAX endtop setting of H-bot July 30, 2015 05:14AM |
Re: MAX endtop setting of H-bot August 04, 2015 01:47PM |
Re: MAX endtop setting of H-bot August 04, 2015 05:53PM |
Re: MAX endtop setting of H-bot August 05, 2015 03:35AM |
