Error message while compiling Marlin for auto-leveling August 03, 2015 11:28PM |
Re: Error message while compiling Marlin for auto-leveling August 04, 2015 06:48PM |
Re: Error message while compiling Marlin for auto-leveling August 04, 2015 08:12PM |
Re: Error message while compiling Marlin for auto-leveling August 10, 2015 12:16PM |
thetazzbot
There is no way your probe could be Y -.10 mm from your hot end.
I suggest you revisit how you came by that number.
it is the position of the probe in relation to the nozzle tip.
So, usually you mount the probe to the side, and in front or back of the nozzle.
Re: Error message while compiling Marlin for auto-leveling August 10, 2015 12:35PM |
Re: Error message while compiling Marlin for auto-leveling August 13, 2015 01:13PM |
deaconfrost
is your hotend 0.1mm behind the nozzle, just make it 0, and if you get problem with x, make that 30, the decibel can be your problem, it was in my case, only on z it will accept decibel, mine is 0.7mm, I just made it 1 and all works well. also if you get problem with it printing in mid air, comment out #define Z_RAISE_AFTER_PROBING, in the slicer g-code, whichever you using, instead of having just G28, make it
G28 X0 Y0; Home extruder
then add these under it, leave the rest if you have no other changes you want to make to the start g-code
G28 Z0
G29
G1 X0 Y0 F4000
G1 Z.2
Re: Error message while compiling Marlin for auto-leveling August 13, 2015 07:37PM |
Re: Error message while compiling Marlin for auto-leveling August 13, 2015 09:16PM |
Re: Error message while compiling Marlin for auto-leveling August 13, 2015 09:46PM |
Re: Error message while compiling Marlin for auto-leveling August 14, 2015 01:18AM |
Re: Error message while compiling Marlin for auto-leveling August 14, 2015 02:01AM |
Re: Error message while compiling Marlin for auto-leveling August 14, 2015 06:33AM |
Re: Error message while compiling Marlin for auto-leveling August 14, 2015 01:05PM |
deaconfrost
What happens if you click the home all button in repetier instead of individual homing?
Re: Error message while compiling Marlin for auto-leveling August 14, 2015 04:54PM |
Re: Error message while compiling Marlin for auto-leveling August 14, 2015 05:04PM |
Re: Error message while compiling Marlin for auto-leveling August 14, 2015 06:17PM |
Re: Error message while compiling Marlin for auto-leveling August 15, 2015 02:02AM |
in configuration.h : #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. in configuration_adv.h : #define ENDSTOPS_ONLY_FOR_HOMING // If defined the endstops will only be used for homing
Re: Error message while compiling Marlin for auto-leveling August 15, 2015 06:19AM |
Re: Error message while compiling Marlin for auto-leveling August 15, 2015 11:04AM |
Re: Error message while compiling Marlin for auto-leveling August 15, 2015 05:38PM |
Re: Error message while compiling Marlin for auto-leveling August 17, 2015 08:32AM |
