Induction Heated Nozzle August 11, 2010 10:15AM |
Re: Induction Heated Nozzle August 11, 2010 01:14PM |
Re: Induction Heated Nozzle August 11, 2010 02:12PM |
Re: Induction Heated Nozzle August 11, 2010 05:31PM |
Re: Induction Heated Nozzle August 11, 2010 06:19PM |
Re: Induction Heated Nozzle August 11, 2010 06:22PM |
Re: Induction Heated Nozzle August 11, 2010 06:27PM |
Re: Induction Heated Nozzle August 11, 2010 06:55PM |
Admin Registered: 17 years ago Posts: 7,879 |
1. The nozzle can be made much smaller and therefore have a much lower thermal mass. (Benefits quicker response, lower wattage and a smaller melt zone)
Re: Induction Heated Nozzle August 11, 2010 07:03PM |
Re: Induction Heated Nozzle August 11, 2010 07:23PM |
Re: Induction Heated Nozzle August 11, 2010 09:09PM |
Re: Induction Heated Nozzle August 12, 2010 04:19AM |
I was thinking along the lines of 1 amp 12v through 24 turns of primary giving something like 0.5v at 24 amps in the secondary (nozzle).
Initial thoughts on the magnet wire were 0.5mm sqr (rated at over 1 amp)
Re: Induction Heated Nozzle August 12, 2010 09:41AM |
Re: Induction Heated Nozzle August 12, 2010 09:56AM |
Re: Induction Heated Nozzle August 12, 2010 10:07AM |
Re: Induction Heated Nozzle August 12, 2010 12:13PM |
Re: Induction Heated Nozzle August 12, 2010 01:30PM |
Re: Induction Heated Nozzle August 26, 2010 06:28AM |
Re: Induction Heated Nozzle October 13, 2010 01:32PM |
jbayless
Dear Fluxtrol,
I am a senior engineering student at the university of British Columbia, and leading a student design team to develop an improved 3D printer. I'd like to use inductive heating, but I haven't learned about it at university, and I'm in need of some expert advice. My question is probably a bit unusual, but maybe you will find it an interesting problem.
So in our 3D printer, we build a model up one layer at a time by melting a plastic rod and extruding it through a fine nozzle. Normally the plastic is pushed into a resistively-heated metal tube, with a fine hole drilled at the end. However, it is important that the plastic transitions from solid to liquid over as short a distance as possible, and so a metal tube is not ideal - its high temperature conductivity makes it hard to make a steep thermal gradient.
I am investigating the use of a glass tube instead. We can easily draw it to a fine nozzle at one end, and take advantage of the low thermal conductivity of glass to achieve a steep temperature gradient. The problem is the resistive heater: It is difficult to transfer heat from the outside of the tube to the inside, because of the thermal resistance. A high heat flow is needed, so the temperature of the heating element must become exceptionally high - wrapping a heating element around the outside poses a problem. The thermal resistivity of the glass therefore both an attraction and a problem: it's good for maintaining a steep temperature gradient axially along the tube, but terrible for allowing heat to flow radially into the tube center from the outside.
That's why I would like to use an inductive heating system. I picture slipping a thin ring of resistive metal, such as stainless steel, into the glass nozzle. Then it can be wirelessly heated by a copper coil wound onto the glass nozzle. The ring will in direct contact with the plastic, and the thermal resistance of the glass will now only be an advantage - insulating the heater radially and axially.
The plastic only needs to be heated to 260 degrees Celsius to melt, which will require four to eight watts, depending on the flow rate. It's a 3 mm diameter plastic filament, so the metal ring should have an outer diameter of no more than 3.2 mm and as small a wall thickness as possible. We would like to drive the coil from a 12 volt AC power source, and the frequency should not be so high that it requires expensive electronics.
Beyond that, I am not sure about the details required. If I want a stainless ring of only 0.1 to 0.2 mm wall thickness, do I need to be concerned about the skin depth? Will I have a very low "K" factor unless I use a high frequency? Do you have any concerns about my design that I should be aware of?
Thank you very much for your help!
Jacob
Fluxtrol
Hi Jacob,
Thank you for your interest in Fluxtrol Inc.
Unfortunately, use of 12 V at 60 Hz will result in almost 0% efficiency for this type of load. The desired frequency range for the part you are trying to heat is 500 - 1000 kHz. In this frequency range, this could be a very nice application of induction heating and efficiencies should be in excess of 80%. For such a low power , the circuitry could be relatively simple and inexpensive. I would suggest you recruit some EE's to work on the project with you.
Re: Induction Heated Nozzle October 13, 2010 02:26PM |
Re: Induction Heated Nozzle October 13, 2010 08:13PM |
Re: Induction Heated Nozzle October 13, 2010 09:51PM |
Re: Induction Heated Nozzle October 14, 2010 12:26AM |
Re: Induction Heated Nozzle October 14, 2010 02:17AM |
Re: Induction Heated Nozzle October 14, 2010 09:15PM |
Re: Induction Heated Nozzle October 15, 2010 01:45AM |
Re: Induction Heated Nozzle October 15, 2010 03:59AM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Induction Heated Nozzle October 15, 2010 03:07PM |
Re: Induction Heated Nozzle October 15, 2010 03:35PM |
Re: Induction Heated Nozzle October 15, 2010 03:38PM |
