Lead Screw Backlash August 31, 2015 07:10AM |
Re: Lead Screw Backlash August 31, 2015 07:20AM |
Re: Lead Screw Backlash August 31, 2015 07:32AM |
Re: Lead Screw Backlash August 31, 2015 09:56AM |
Re: Lead Screw Backlash August 31, 2015 10:09AM |
Re: Lead Screw Backlash August 31, 2015 10:54AM |
Re: Lead Screw Backlash August 31, 2015 11:42AM |
Re: Lead Screw Backlash August 31, 2015 04:46PM |
Re: Lead Screw Backlash September 01, 2015 03:00AM |
Re: Lead Screw Backlash September 01, 2015 03:33AM |
Well, all you say may be different, depending of the motor.Quote
691175002
You can hit essentially zero backlash just by lightly spring-loading two nuts. This strategy is sometimes used in machine tools but is limited by rigidity and force constraints. A 3d printer has fairly tame loads so there aren't many drawbacks.
Leadscrews are generally a poor choice when you are looking for high accelerations. If you look at motor sizing calculations you will discover that that each gram of screw is equivalent to ~10g of extruder mass.
The extruder is relatively easy to accelerate because a small motor can apply a large force through the mechanical advantage of a timing pulley or screw. The screw itself must be directly attached to the motor shaft so you get no mechanical advantage and it really slows things down.
This gets exponentially worse for short-lead screws. Accelerating a screw from 0 to 1200RPM is going to take a hell of a long time compared to the equivalent timing belt.
Re: Lead Screw Backlash September 01, 2015 04:02AM |
Re: Lead Screw Backlash September 01, 2015 07:49AM |
Re: Lead Screw Backlash September 01, 2015 10:15PM |
Re: Lead Screw Backlash September 02, 2015 12:00PM |
o_lampe
Wouldn´t the higher pitch of a lead screw outweight the acceleration issue? Saying, it doesn´t have to turn fast to achieve high speed at the gantry?
-Olaf
Re: Lead Screw Backlash September 03, 2015 01:10AM |
Re: Lead Screw Backlash September 03, 2015 04:36AM |
Re: Lead Screw Backlash September 03, 2015 07:02AM |
