Extruder making clicking noise and not extruding enough plastic September 02, 2015 11:47PM |
Re: Extruder making clicking noise and not extruding enough plastic September 03, 2015 01:36PM |
Re: Extruder making clicking noise and not extruding enough plastic September 03, 2015 02:52PM |
Re: Extruder making clicking noise and not extruding enough plastic September 03, 2015 08:10PM |
Re: Extruder making clicking noise and not extruding enough plastic September 04, 2015 02:52AM |
munchit1
i've just been having a similar issue, with the click click click from the extruder teeth area, i slowed the prints 5mm/s a time till it hushed up. (i wasnt losing any extrution though.) i'll try the unclockit method next time.
full storry,
working fine untill long straight infill lines then click click untill the lines were shorter..hense i slowed stuff down a touch. (only getting about 65-75 mm/s though...direct drive with one toothed cog).
Re: Extruder making clicking noise and not extruding enough plastic September 05, 2015 08:56AM |
Re: Extruder making clicking noise and not extruding enough plastic September 05, 2015 09:00PM |
Re: Extruder making clicking noise and not extruding enough plastic September 05, 2015 10:18PM |
Re: Extruder making clicking noise and not extruding enough plastic September 06, 2015 02:33AM |
Re: Extruder making clicking noise and not extruding enough plastic September 06, 2015 03:08AM |
Re: Extruder making clicking noise and not extruding enough plastic September 06, 2015 03:47AM |
Re: Extruder making clicking noise and not extruding enough plastic September 06, 2015 06:05AM |
SkeptikRC
I'm not sure how to find the specifics but its the one attached to the geeetech mk8 extruder.Quote
Koenig
What is the motor rated for and much current are you feeding the stepper?
Re: Extruder making clicking noise and not extruding enough plastic September 06, 2015 04:46PM |
Koenig
SkeptikRC
Koenig
From the video its easy to see its skipping steps, what did you set vref on the drivers to and which drivers are you using?
Re: Extruder making clicking noise and not extruding enough plastic September 07, 2015 12:57AM |
Re: Extruder making clicking noise and not extruding enough plastic September 09, 2015 10:06AM |
Re: Extruder making clicking noise and not extruding enough plastic September 21, 2015 03:27AM |
