Fire safety device October 24, 2015 06:07PM |
Re: Fire safety device October 25, 2015 11:22AM |
Re: Fire safety device October 25, 2015 03:57PM |
wes1007
Use an Arduino a transistor and a relay.
Smoke detector provides a signal to the Arduino which then triggers a transistor to turn a NC relay off. code it so that once the smoke detector is triggered you either press a button to reset or you just reset the arduino.
Be careful with smoke detectors. There are 2 types (cant remember the types). One picks up smoke and the other picks up burning without smoke (or something alone those lines.) Would probably be a good idea to have one of each.
Re: Fire safety device October 25, 2015 04:16PM |
Re: Fire safety device October 25, 2015 04:39PM |
Re: Fire safety device October 25, 2015 04:45PM |
Re: Fire safety device October 25, 2015 04:52PM |
Re: Fire safety device October 29, 2015 04:56AM |
Re: Fire safety device October 29, 2015 06:39AM |
Re: Fire safety device October 29, 2015 07:02AM |
Re: Fire safety device October 29, 2015 07:42AM |
DjDemonD
Does anyone know if there are any plans/experiments to use some pins on the Ramps or other controller boards as trigger for smoke detectors which would immediately kill the print, shut off the heaters/motors and essentially remain in an off state until manually reset. It seems odd that with these versatile devices no one is doing this already? I would try this myself but I am not at the point of being able to modify marlin to do this even if it is possible with the hardware I have (ramps 1.4).
Re: Fire safety device October 29, 2015 09:47AM |
Re: Fire safety device October 29, 2015 10:58AM |
Re: Fire safety device October 29, 2015 11:18AM |
Re: Fire safety device October 29, 2015 01:21PM |
Re: Fire safety device October 29, 2015 05:12PM |
Re: Fire safety device October 29, 2015 06:27PM |
Re: Fire safety device October 30, 2015 05:29AM |
Re: Fire safety device October 30, 2015 01:10PM |
Re: Fire safety device October 31, 2015 11:20AM |
Re: Fire safety device October 31, 2015 05:22PM |
Re: Fire safety device April 07, 2020 09:58PM |
Re: Fire safety device April 08, 2020 03:41AM |
Re: Fire safety device April 08, 2020 10:40AM |
Re: Fire safety device April 08, 2020 10:42AM |
Re: Fire safety device April 08, 2020 11:03AM |
Re: Fire safety device April 08, 2020 12:33PM |
loddie
DjDemonD
...use an rcd or rcbo type device on the mains supply to trip power in case a wire or the heat bed shorts to anything.
I'll be using a GCFI outlet to plug the printer into. Is a GFCI outlet functionally equivalent to an RCD/RCBO?
Re: Fire safety device April 08, 2020 11:09PM |
