See print layer
November 11, 2015 01:51PM
hi
please help
Please see the photo
Because of the outside layers
Why not clean and smooth surface?
open | download - 2.jpg (102 KB)
open | download - photo_2015-11-11_22-17-04.jpg (85.3 KB)
open | download - 3.jpg (74 KB)
Re: See print layer
November 11, 2015 02:38PM
There appears to be some belt lash - the layers are shifting alternately.
The first thing is to make sure everything moves easily and smoothly, and that your belts are tight.
Also make sure you have ground flats on the stepper motor shafts, so the drive pulleys do not shift.
My printer: Raptosaur - Large Format Delta - [www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the Wiki!
Re: See print layer
November 11, 2015 03:06PM
Thanks for your answer
Belts are horny
no problem
Dimensions 600 x 600 x 600
please help
open | download - 4.jpg (98.9 KB)
open | download - 5.jpg (101.3 KB)
open | download - 6.jpg (94.2 KB)
Re: See print layer
November 11, 2015 03:19PM
Two stepper motors for axis
With two separate drive
Motors and drivers similar
Trouble layer along the axis y
The motor may be a problem?
Re: See print layer
November 11, 2015 03:21PM
OK. Edit: I'm not sure what's happening - I think you are indicating it happens only along one axis.
If you look closely at your first object (hollow one) at the bands, are the layers shifted? Looking at an individual layer - is it out on one side and in on the other?
Or are the bands just alternating thicker and thinner?
Edited 1 time(s). Last edit at 11/11/2015 07:02PM by Paul Wanamaker.
Re: See print layer
November 12, 2015 02:46AM
Thanks
happen if the belt is shaky due to the great distance?
It was the first GT2 belts
Because we used a low belt.Width 10 mill Just for Y axis . x axis GT2
I'm bored. I do not know what to do with this problem
Y axis is perhaps to be heavy.
But quite smooth and comfortable moves
Re: See print layer
November 12, 2015 02:58AM
Complete mechanism is identified in the image below.
Please comment on the mechanism announced
open | download - 7.jpg (88 KB)
Re: See print layer
November 12, 2015 06:51AM
New piece of a glass
Please look try and help
No one could help.
Only the belt is loose?
Tighten the belt is not moving
There was no information regarding the timing belt, how much I have to go to tie the timing belt ?
open | download - 8.jpg (53.4 KB)
open | download - 9.jpg (67 KB)
open | download - 10.jpg (125.7 KB)
Re: See print layer
November 12, 2015 08:24AM
You're extruding too hot IMHO.
Your gantry looks heavy.
Try to set the speed down.
If you print in PLA you need some cooling on the part too.
++JM
Re: See print layer
November 12, 2015 11:51AM
Thanks for answer
X axis is the total weight of 3500 g
Two motor is 3.5 k to draw the X axis
Do you think the heavy axis?
Please see first post photos
Re: See print layer
November 12, 2015 01:43PM
As J-Max said, 3500g seems very heavy. Others with your style of printer can comment (I have a delta).
What exact style is it?
To see if the weight is in fact the problem (as he stated) slow the print and travel speeds down! Very slow as a test. Example speeds: 30mms for printing, 60mms travel. Reduce the acceleration. You should tell us what speeds and acceleration you are using.
J-Max also said you may be printing too hot. It looks like you are printing PLA? At what Temperature? Using a cooling fan?
That is enough changes for one test. You don't need to print it very tall - enough to see if the layers stay even. Is it better?
As for tightening the timing belts, you can get a rough unscientific estimate of the tightness by plucking them like the string on a guitar. Do they produce a medium tone, or a very low tone? You should only be able to push the belt in a small amount with your finger.
We'll talk later about what motors you are using, and at what current.
Re: See print layer
November 12, 2015 02:42PM
Also might be Z wobble. The design you have doesn't look like it would be too much of a problem, but if the bearings have some play and the Z screws are slightly bent it might still cause this issue.
Re: See print layer
November 12, 2015 04:34PM
This piece has a height of 300m.The z axis proves no problem
open | download - 812320490_102218.jpg (85 KB)
Re: See print layer
November 12, 2015 09:35PM
It seems like we are having a hard time communicating, but I'll try again. Z Wobble is when the spinning Z screws cause the moving build plate to wiggle back and forth. It has nothing to do with how high your Z axis can go. If your Z lift screws are bent they can sometimes force the build plate out of place by a small amount. It doesn't take much movement to mess up your layer alignment. Are your Z screws secured in more than two places? Z screws should generally only be attached to the motor and to the build plate. If there is another bearing or bushing in the middle that may make things worse.
Try this. Make an X on your build plate. Bring it up to 0,0,0, and center the hot end on the X, then drive the build plate down and watch how the X moves versus the hot end. Does it seem to move straight down or does it also wobble back and forth as it goes down?
Bryan
Edited 1 time(s). Last edit at 11/12/2015 09:38PM by bryanandaimee.
Re: See print layer
November 13, 2015 02:32AM
Paul Wanamaker
Thanks
I tried with the lowest rate. Not satisfactory
High-speed printing is better
There is only risk the loss of calibration
Re: See print layer
November 13, 2015 03:27AM
bryanandaimee
Bryan
Thanks
Are there four bars and two ball screw allows wobble axis z
I also suspect the z axis
Is there a way to make sure?
It is unbelievable
z axis is specified in the picture
open | download - 1.jpg (77.5 KB)
Re: See print layer
November 13, 2015 04:39AM
Z axis calibration
Ball Screw with step 1.75
Timing belt XL
Two Foley.
A 16 Tooth for Moto
20 Tooth Ball Screw
Stepper motors 1.8
Please calculate
How to calculate how?
Re: See print layer
November 13, 2015 08:34PM
I was happy to find this nice calculator
I plugged the numbers into the "Steps per millimeter - leadscrew driven systems" calculator and find:
2285.71 steps per mm
I worked out how they calculated it:
200 steps per revolution x 16 microsteps x (20/16) / 1.75 = 2285.71 steps per mm
Note that your z is only moving 0.0004mm per step.
Smaller steps causes a high step rate.
A high step rate with a stepper moter causes low torque. See Here.
Low torque can cause missed steps - especially when there is a sudden change in direction, or acceleration. (Make sure the acceleration is not too high.)
Maximum torque is at the low revolutions per minute.
In my opinion, your steps per mm is high. I'll comment further if you like.
I don't know what you mean by "two Foley". Foley is an uncommon word.
Re: See print layer
November 15, 2015 05:12AM
Thank
Number 2870 is near to calibrate
I think the step inaccurate Ball Screw 1.75
Do you think delaminate due to high levels of Z-axis is the piece?
Way to deal with this problem?
By lowering speed the Z axis is problem solving?
Excuse me for the bad grammar
Re: See print layer
November 15, 2015 11:51AM
I think the language issue is the biggest problem.
It will help you a greatly if you can have someone translate this, otherwise we both misunderstand.
Many things we have asked have still not been answered, and we need to know in order to diagnose the problem.
I am going to give one last try.
Your question could have two meanings!
- If there is a problem with delamination then it could be the layer height is too high. What layer height are you using? Try using .20mm layer height.
- It could be you are missing steps on the Z due to either too high of a step rate, or. Easy to determine, just lower the Travel Speed to a very low number line 40 and test. If that doesn't fix it then Lower acceleration in the firmware and test. If that doesn't fix it then lower Jerk settings in firmware and test.
My advice when testing this or any new printer: do not use any speeds above 50. If everything is good then increase speeds gradually. The defaults in firmware are too high for speeds and acceleration.
Unfortunately these questions miss the original issues
I'm going to give you some possibilities, but you need this translated!
- Are the layers still shifted? Best to provide photos of both sides of a part.
- If the layers are shifted then several things could be happening at once (Note: you can search the forums for "Shifted Layers")
  1. The speeds and accelerations could be too high for the stepper motors to handle the moving mass, and if the moving mass is too large for their torque at that speed they will loose steps when changing direction (accelerating and decelerating). They loose torque at the higher speeds. See the next item for possible solutions.
  2. The axis may be too heavy - if so then you must lower acceleration in the firmware, lower Jerk, and lighten the axis as much as possible so there is less moving mass. Use one motor in a moving axis if two motors are not needed. Use a Bowden extruder, etc. to move the motor off the axis.
  3. Stepper motor current may be too high and the stepper drivers may be resetting (this usually causes large offsets, but could cause small ones if the thermal reset is short) - mount a fan to cool the drivers, adjust the current.
  4. Stepper motor current may be too low and so the stepper motors may not have enough torque. (Search the forum for "Adjust Stepper Driver Current")
  5. Steps could be too fast for the controller. The old 8-bit controllers can only output steps evenly when the step rate is below a critical speed, then they start to stutter, causing lost steps, which causes an offset or shift. This is normally more of an issue with Delta printers, but could be an issue if you have a full-graphics controller. Probably not the issue here. The solutions are to lower the speeds, use the right sized pulleys, lower the microstepping rate for the axis, get a 32-bit controller, etc.
  6. The Z axis could be wobbling due to a ball screw that is not strait. Unlikely, as I see from your photo that the top of the ball screws are not fixed in place. However, have you tried James' advice above to be sure?
I think I have listed most of the possibilities.
I'm afraid this is all the help I can offer on your issues.
There may be a forum in your language, or someone may be able to translate, and you can search for Shifted Layers in the forums, or post in a section below that is specific to your type of printer.
Best wishes.
-Paul
Edited 1 time(s). Last edit at 11/15/2015 11:57AM by Paul Wanamaker.
