Heatsink for solid state relais? November 14, 2015 06:38PM |
Re: Heatsink for solid state relais? November 14, 2015 10:05PM |
Re: Heatsink for solid state relais? November 14, 2015 10:53PM |
Re: Heatsink for solid state relais? November 15, 2015 01:49AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: Heatsink for solid state relais? November 15, 2015 03:26AM |
Re: Heatsink for solid state relais? November 15, 2015 05:51AM |
Re: Heatsink for solid state relais? November 15, 2015 11:43AM |
Srek
A good SSR for AC will switch while the sine curve is at 0 (zerocrossing). Due to this there is no load at switch time. Cooling is not neccesary.
Re: Heatsink for solid state relais? November 15, 2015 03:02PM |
That's correct. The mentioned SSR though can handle up to 25 A, which is more than 10 times what most heatbeds only ever go up.Quote
tjnamtiw
Srek
You are only talking about the switching on and off of the relay but you don't address the conduction of power through the SSR. A typical SSR absorbs 1 to 2% of the power it is passing so at some point if you draw enough power, the juncture will approach its failure point.
Re: Heatsink for solid state relais? November 15, 2015 03:32PM |
Srek
tjnamtiw
Srek
Re: Heatsink for solid state relais? November 15, 2015 03:37PM |
tjnamtiw
Srek
Re: Heatsink for solid state relais? November 15, 2015 04:10PM |
dc42
3. Good DC-DC SSR (e.g. Crydom DC100D40) dropping 0.14V @ 20A and driving a 24V bed heater: about 0.6%..
