2robotguy
Because you used the word, Objet, I went to see what it is. It looks like Objet makes some very nice prototyping 3d printers. The only problem is that it seems to be a single print job per setup rig, like most 3d printers. (Like the old Gutenburg printing press was.) Only just today did I see any exception to that rule, The Makerbot with Automated Build Platform, which more or less prints and resets for the next print job and starts again. (Imagine replacing the original press with rollers that can print multiple copies until service is needed) My idea was that you would load a printing platform let the machine print there and then switch the platform at the end of each job, but in some ways the heated conveyor belt idea is better. The down side is that once the part comes off the platform, its position is more or less random which forces further handling to be human or at least very sophisticated, beyond what most people would want to take on. It looks like the Objet is problably an order of magnitude more precise than any reprap system but probably costs a whole lot more per cubic cm to print with. Perhaps a great deal more if someone worked out a decent way to shred and reconstitute recyclable ABS Plastic. (big challenge)
I would expect the extruders to wear out. Only those people who have been printing a lot would know, I suppose. That said, I would think that if the printer rig was made so that the print head moved on only the z axis or not at all, it would be possible to make a mounting surface for it that is stable enough that one could prepare and calibrate a print head elsewhere and lock it in when a replacement is necessary. Regardless, there is still hope of automatic calibration after a new head or print site cartridge is replaced. The idea here is If the extruder needs service, replace it. If the print site module needs replacing, replace it, and find ways to make both replacements straightforward and non-problematic. (a challenge, but doable) I'd bet that rebuilding a print head wouldn't involve that much new material. If the head was designed to be rebuilt easily, that would help. (similarly, some internal combustion engines have cylinder sleeves and replaceable bearings to make rebuilding straight forward.) The idea is to think modular and allow for easy replacement of those modules that need replacement so that the modules that don't need replacing at any one time can stay productive. At this point I think 3 modules are called for, the control module, printhead module, & print site module.
As for the meaning of "SSYS" machines, I am at a complete loss. I do know that I am talking about printing with thermoplastics like ABS or PLA, usually available in the long filament spools like we see all the time or in pellets. I haven't given up on the hope that someone might find a way to collect and recycle ABS and make it usable in these printers. Find a path to that and you find a very cheap source of printing material. PLA plastic is generally made from corn around where I live, so that should stay readily available. (To bad it doesn't hold up at hight temps)
The equation comes down to this. Find a way to get cheap abundant "printing" material. Make a rig that is very fault tolerant, (through switching out failed and completed modules) and you've got a system that can be very productive, especially if you can automate the switching out process. One doesn't have to start out with high precision either. Lord knows there are some **UGLY** print jobs out there, but we start where we start and thing improve over time. As for whether we should be working on one concept or another, things aren't necessarily mutually exclusive. You may come up with a cool idea that helps extruders work better, while I figure out something about the axis control system. Besides, Ideas come on their own terms, to whomever they chose. We just need to be responsive when they come our way.
