Heatsinkless hotend January 21, 2016 05:10AM |
Re: Heatsinkless hotend January 21, 2016 05:25AM |
Re: Heatsinkless hotend January 21, 2016 05:42AM |
Re: Heatsinkless hotend January 21, 2016 06:04AM |
Re: Heatsinkless hotend January 21, 2016 06:29AM |
Re: Heatsinkless hotend January 21, 2016 06:38AM |
the_digital_dentist
The QUBD extruders are similar, and so are the extruders on the old Makerbots.
Cannot be jammed? Hmmmm. As I recall, the QUBD and the Makerbot extruders were jammed most of the time.
Re: Heatsinkless hotend January 21, 2016 08:27AM |
Re: Heatsinkless hotend January 22, 2016 04:33AM |
Floyd
Did no one else notice the huge blower pointed at the threaded part of the hot end?
I dont like how its mounted. The heater cartridge is right near the mounting point soaking heat into the printer and the nozzle. Not really the best idea but if it works then good job.
Re: Heatsinkless hotend January 22, 2016 09:59AM |
Re: Heatsinkless hotend January 22, 2016 10:08AM |
Re: Heatsinkless hotend January 23, 2016 12:19PM |
Re: Heatsinkless hotend January 23, 2016 02:30PM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: Heatsinkless hotend January 23, 2016 03:17PM |
Re: Heatsinkless hotend January 23, 2016 03:18PM |
Re: Heatsinkless hotend January 23, 2016 03:20PM |
Re: Heatsinkless hotend January 23, 2016 03:31PM |
Agree.Quote
thejollygrimreaper
yeah ... not exactly a speed daemon, 500mm/min only equates to 8.3mm/sec which in printing terms isn't exactly what i would call fast personally i'm running between 60mm/sec and 90mm/sec and others run a lot faster
the only reason that hotend "works" is simply down to the ptfe tubing inside the stainless tube and you'll be getting a huge meltzone so i wouldn't expect retraction to be very helpfull
Re: Heatsinkless hotend January 23, 2016 09:43PM |
Re: Heatsinkless hotend January 24, 2016 01:30AM |
karabas
Agree.Quote
thejollygrimreaper
But stratasys(dimention) melting zone as twice as longer and retract works.
I want to try their nozzles.
BTW what hotends do you speed up to 60-90mm/sec?
Re: Heatsinkless hotend January 27, 2016 06:38AM |
Re: Heatsinkless hotend January 27, 2016 08:37AM |
karabas
PEEK part is about it.Quote
reifsnyderb
J-Heads don't have heat-sinks. Genuine J-Heads don't need heat-sinks.
