Best ( simplest ) controller February 07, 2016 02:23PM |
Re: Best ( simplest ) controller February 07, 2016 03:39PM |
Re: Best ( simplest ) controller February 07, 2016 04:25PM |
Re: Best ( simplest ) controller February 07, 2016 04:29PM |
Re: Best ( simplest ) controller February 07, 2016 05:02PM |
Re: Best ( simplest ) controller February 07, 2016 05:44PM |
Re: Best ( simplest ) controller February 07, 2016 05:57PM |
Re: Best ( simplest ) controller February 08, 2016 02:03AM |
Re: Best ( simplest ) controller February 08, 2016 03:38AM |
Re: Best ( simplest ) controller February 08, 2016 05:44AM |
Re: Best ( simplest ) controller February 09, 2016 02:37AM |
Re: Best ( simplest ) controller February 09, 2016 03:07PM |
Re: Best ( simplest ) controller February 09, 2016 04:33PM |
Re: Best ( simplest ) controller February 12, 2016 09:27AM |
Re: Best ( simplest ) controller February 13, 2016 07:48AM |
the_digital_dentist
What's "forgiving" about it?
Re: Best ( simplest ) controller February 13, 2016 08:59AM |
But that has nothing to do with the ramps/Arduino but with the design of the driver module. And also it's very easy to connect an other more robust driver to the ramps. The best way I found to blow up the stepper module is by moving the X Carriage on my Prusa I3 fast and serveral times by hand.Quote
the_digital_dentist
It is definitely common, but the motor driver modules are easy to blow up,
That's because the recommended maximum input voltage is 12volts. Yes maybe the designer could have increased that maximum but again is not really an issueQuote
the_digital_dentist
voltage regulator dies if you apply more than 12V to most of them
I run only ABS for almost 3 years now and never had a ramps die on me because of burned traces. In fact still use the ramps I started with.Quote
the_digital_dentist
and traces burn up if you use a heater than gets the bed hot enough to print ABS.
Re: Best ( simplest ) controller February 15, 2016 03:36AM |
Re: Best ( simplest ) controller March 01, 2016 01:50PM |
Re: Best ( simplest ) controller March 11, 2016 01:01PM |
