Center of bed is not right February 08, 2016 05:39PM |
Re: Center of bed is not right February 09, 2016 12:38AM |
Re: Center of bed is not right February 09, 2016 12:55AM |
Re: Center of bed is not right February 09, 2016 01:44AM |
Wesley_125
Yes it should be X110 Y110 the X center is right, the printer worked before that, and i adjusted the Y steps because it was not making the right steps 10mm manual control was 6mm after changing the steps i printed A test print of 15x15x3 and it prints perfectly 15x15x3 i will try theG1 Y100 F2000 command and i'm using repetier software with cura engine where can i find it in cura engine? In repetier host i cant find the printer settings in cura in slic3r i found them but not cura.. It's strange because X Y Z steps where all wrong after changing the steps i got the right dimensions. X was then also not centered after changing X it centred but if i do the same for Y it keeps putting my object to much up and not in the center
Re: Center of bed is not right February 09, 2016 01:52AM |
Re: Center of bed is not right February 09, 2016 02:12AM |
Wesley_125
But if my Y motor makes the right distance it should be okay? if i move Y 10mm i actually goes 10mm before i changed the steps it moved 6mm instead of 10mm so prints where not the right dimensions.. X and Y steps are 100 per unit. So it may be in printer settings?
Re: Center of bed is not right February 09, 2016 02:47AM |
Re: Center of bed is not right February 09, 2016 02:48PM |
Re: Center of bed is not right February 09, 2016 05:56PM |
Wesley_125
if i do G1 Y100 F2000 it's 105mm and 115mm centre and not 110 110
Re: Center of bed is not right February 10, 2016 05:30AM |
Re: Center of bed is not right February 10, 2016 08:00AM |
Wesley_125
Its very strange the middle of the bed is 110x110 but of i do G1 X100 Y100 than its the middle 110 is to far so the current steps is the problem ?
Re: Center of bed is not right February 10, 2016 09:19AM |
Re: Center of bed is not right February 10, 2016 01:19PM |
Re: Center of bed is not right February 10, 2016 01:41PM |
Wesley_125
hi i did all you set know if i move the axis to 100 it goes to the middle of the bed but when in repetier host using cura to slice i won't work it still prints it way to high in Z axis but i set it in the middle..
Re: Center of bed is not right February 10, 2016 01:44PM |
Re: Center of bed is not right February 10, 2016 01:45PM |
Re: Center of bed is not right February 10, 2016 02:03PM |
Wesley_125
god dam I mean Y axis Y what is wrong whit me i ment Y! its driving me crazy
Re: Center of bed is not right February 10, 2016 02:18PM |
Re: Center of bed is not right February 10, 2016 02:19PM |
Re: Center of bed is not right February 10, 2016 02:40PM |
Re: Center of bed is not right February 10, 2016 03:48PM |
Re: Center of bed is not right February 10, 2016 04:05PM |
Re: Center of bed is not right February 10, 2016 06:16PM |
Re: Center of bed is not right February 11, 2016 12:49AM |
Re: Center of bed is not right February 11, 2016 03:39AM |
Re: Center of bed is not right February 11, 2016 04:11AM |
Re: Center of bed is not right February 11, 2016 01:25PM |
Re: Center of bed is not right February 11, 2016 03:08PM |
Re: Center of bed is not right - Solved February 12, 2016 02:30AM |
Re: Center of bed is not right - Solved February 12, 2016 06:19AM |
