Makerbot 3G and firmware question
Posted by AgeingHippy
October 06, 2010 07:09AM
Hi All
I have pre-assembeled Makerbot 3G electronics (purchased about 4 months ago).
I am approaching the point where I will need to start working on the electronics and was wondering if I need to update the firmware on the motherboard if I wish to run with the latest stable version of Reprap Host.
I will be using a stepper motor using a geared extruder and I am aware Makerbot use a servo motor(?) so will need to take this into account as well.
Cheers for any advice.
VDX
Re: Makerbot 3G and firmware question
October 06, 2010 07:32AM
AFAIK the Makerbot-boards are programmed for use with ReplicatorG and DC-motor, so for RepRap-Host and stepper you have to change the firmware on the motherboard and the extruder ...
Are the boards from Makerbot or another manufacturer?
For some of the cloned extruder-boards (not red in colour) you have to solder a short connection on two jumper-pads located left of the oszillator to connect GND with AGND, or it won't work properly ...
Viktor
October 06, 2010 08:41AM
Hi Viktor
I purchased the pre-assembled boards from Makerbot.
Cheers
VDX
October 06, 2010 08:43AM
... OK, so they're preprogrammed for ReplicatorG and you have to replace the firmware for RepRap-host only ...
Viktor
