Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 08:59AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 09:20AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 09:44AM |
McSquid
Though the microwave idea seems unrealistic.
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 09:54AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 10:50AM |
McSquid
I'm far from an expert but I just see many issues getting in the way. Uneven heating/cooling, Pouring not creating enough pressure (without a vacuum to fill out your mold) etc. Don't let my fairly uninformed skepticism stop you from experimenting!
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 11:28AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 11:34AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 11:54AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 11:59AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 01:10PM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 18, 2016 08:41PM |
http://naldc.nal.usda.gov/download/4048/PDF
- "PLA undergoes thermal degradation at temperatures above 200C (392F) by hydrolysis, lactide reformation, oxidative main chain scission, and inter- or intramolecular transesterification reactions. PLA degradation is dependent on time, temperature, low-molecular-weight impurities, and catalyst concentration."
- "Poly(lactic acid) homopolymers have a glass-transition and melt temperature of about 55C and 175C, respectively. They require processing temperatures in excess of 185–190C. At these temperatures, unzipping and chain scission reactions leading to loss of molecular weight, as well as thermal degradations, are known to occur. Consequently, PLA homopolymers have a very narrow processing window."
" Pure poly(D-Lactide) or poly(L-Lactide) has an equilibrium crystalline melting point of 207C but typical melting points are in the 170C–180C range. This is due to small and imperfect crystallites, slight racemization, and impurities. It has also been observed that a 1:1 mixture of pure poly(L-lactide) with pure poly(D-lactide) will yield an insoluble gel formeby the stereocomplexation (racemic crystallite) of the two polymers during crystallization or polymerization. This pure stereocomplex has a melting point of 230C and mechanical properties greater than either pure polymer"
- " Poly(lactic acid) quickly loses its thermal stability when heated above its melting point. A significant level of molecular degradation occurred when PLA was held 10C above its melting point (160C) for a sustained period of time." ... here the "sustained" periods were in the range of 30 minutes, which is much more than I expect for a quick processing.
-"However, brittleness and other properties such as low viscosity, low thermal stability, high moisture sensitivity, medium gas barrier properties, high cost (comparing with PE, PP, PS…) and low solvents resistance (e.g., against water) of the pure polymer are often insufficient for a lot of applications."
http://www.wseas.us/e-library/conferences/2011/Corfu/GEMESED/GEMESED-70.pdf
- "The experiments were performed at two different temperatures 170, and 190C keeping constant along the reservoir and capillary zone. [...] The resin melting time of three minutes was kept in order to prevent polymer degradation from long residue time. "
"[...] low data set at temperature of 190C has significantly lower values of viscosity in the whole range of shear rate compared to the flow behaviour of tested PLA at 170C. Furthermore, shear viscosity of tested PLA decline with increasing shear rate for the each mean pressure indicating a preservation of shear thinning behaviour typical for a common thermoplastic polymer. Thus it can be concluded that the pressure increase in the PLA melt did not influence the shear thinning behaviour while it effects only on the magnitude of viscosity. "
http://www.plastemart.com/upload/Literature/ProcessingofPLA%28biopolymer%29.asp
- "PLA picks up ambient moisture very rapidly and most of the problems experienced on PLA arise from inadequate drying. Hence, PLA is required to be properly dried before processing."
- "PLA viscosity is also very sensitive to temperature and moisture, so PLA web tends to stretch and sag unevenly. PLA also shrinks 9% in the transition from melt to solid, going from a melt density of 1.13 g/cc to a solid density of 1.24 g/cc."
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 01:05AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 02:10AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 03:34AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 04:10AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 06:00AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 08:15AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 08:24AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 09:00AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 09:46AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 10:13AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 19, 2016 10:40AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 20, 2016 02:59AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 20, 2016 07:15PM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 21, 2016 11:55AM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 21, 2016 12:15PM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 21, 2016 12:31PM |
Re: Can we melt PLA pellets to use it for molding? Maybe microwave it? February 21, 2016 01:11PM |
