Removing 3M 468MP adhesive
Posted by WZ9V
March 21, 2016 10:26AM
I've tried Goo Gone Pro but it's just not dissolving the 3M 468MP adhesive.
Can someone recommend a solvent that will dissolve the adhesive. I'll trying to cleanup a glass plate for a new layer of PEI but having a devil of a time getting rid of the old adhesive.
Re: Removing 3M 468MP adhesive
March 21, 2016 10:55AM
Acetone, lots of it, and a couple of the kitchen scourers. you have to remove it progressively, ie, bit by bit gradually. Then use kitchen towels with Acetone.
it is useful to use a sharp blade scraper to get the bulk of it off first.
March 21, 2016 04:46PM
Thanks. I have the bulk of it off and now I'm down to film that just won't let go. I'll go at it with scrubbers and Acetone.
March 22, 2016 10:08PM
I feel for you. I just did that a week ago and used heat, acetone, orange oil (same as goo gone) and a scraper. Spent a good 4 hours making the glass usable again and made a major mess in the process. One person mentioned putting it in the freezer for awhile and another mentioned a product called "Rapid Remover" it's made for removing vinyl lettering like on signs and vehicles.
Good luck and wear gloves.
March 22, 2016 10:39PM
There are times when I think maybe I should just buy another glass plate.
Edited 1 time(s). Last edit at 03/22/2016 10:39PM by WZ9V.
December 25, 2016 11:24AM
You people are making things much more difficult than you need to.
3M 468MP (or 3M 200MP) adhesive is easily removed. You just take a blob of Peanut Butter (Creamy... Not Chunky!) and smear a thin layer across the surface to be cleaned. Try to get a 1/16" layer across the entire sheet. Then just wait over night and use a squidgy to remove the peanut butter. And then soap and water to remove the grease and oil from the peanut butter.
I just did a 400mm x 400mm silicon heater pad with only 10 minutes of actual work.
Edited 1 time(s). Last edit at 12/25/2016 11:26AM by Roxy.
December 25, 2016 12:54PM
I've found alcohol to be more effective than acetone.
Simon.
[www.precisionpiezo.co.uk] Accurate, repeatable, versatile z-probe plus piezo discs, endstop cables, pt100, 50w heaters. PT1000 cartridge sensors plug straight into duet boards and others.
Published:Inventions
October 25, 2017 04:03PM
Roxy
You are so right - peanut butter overnight works amazingly well! 98% off with the first pass of my scraper, then a final round with isopropyl to get off the rest. SO much easier (and less toxic) than the last time I did it (2 hour acetone/alcohol ordeal).
Edited 1 time(s). Last edit at 10/25/2017 04:04PM by yonkiman.
October 25, 2017 04:31PM
I'll bet is smells delicious the next time you turn on the heater!
Son of MegaMax 3D printer: [www.instructables.com]
October 25, 2017 05:48PM
really? Peanut butter.....
damn I have my bed soaking in acetone all night right now....
Used a zip lock static bag as acetone does not dissolve it and I can use a much smaller amount of acetone in there.
Still, I have to remember to try this one!!!
October 26, 2017 03:31PM
Alcohol or gasoline works best.
3M also have a gel that is fantastic for most.
Haven't used it for some years. (expensive)
I do work with adhesives every day. (sign and graphics)
I have never heard about peanut butter..
Ill try that next time I have a customer visit.. lol
October 30, 2017 03:07AM
I had the same problem (spent 4 very messy hours first time) then someone mentioned "Rapid Remover" and it works but it needs help in the form of a GOOD razor scraper ( A cheap one will hurt you) and you should be able to clean off all the glue in 10 minutes.'
February 25, 2020 04:10AM
Roxy
Sorry for resurrecting such and old post but I just wanted to give a big thanks Roxy, Peanut Butter works unbelievably well. I thought it was maybe a prank but it was worth 2 TBSP of Peanut butter to find out. Overnight wrapped in Cling Film and the adhesive just scraped right off. A quick wash and scrub in soapy water and its totally clean. 10 minutes work and saved so much hassle.
