Update!
Well guys thank you so much for your help, I took the following steps:
1. Gutted all electrical components, leaving only the frame.
2. Loosened all fastener bolts, and then refastened making sure to measure out the triangle shape and that the towers were parallel as I was tightening stuff up. Took about twice to do so properly. Got a pair of jumbo 24 in calipers that are supposedly within 0.05mm, but with any calipers, not really... but I feel pretty confident that the towers are pretty close to within 0.05 to 0.1 mm off now, much better than the .2 off they were when I first checked.
3. Installed turnbuckles and wires on two faces suggested by nebbian to adjust for the twist. I could visibly see that my frame was twisted clockwise by a significant amount. I used a L-Square from home depot, the 13 dollar one instead of the 3 dollar one, and adjusted accordingly until I got the inner corners to be straight. Strangely, I couldnt get the front to be straight, seemed like nothing was changing them, but I felt like if the inner corners are straight, maybe the extrusions themselves are not perfect? I dunno kinda weird. It took out the twist visually it seemed, so I figured it was a step in the right direction.
4. Reinstalled all electronics, this included adding a few fans underneath, which I realized I wasn't having stepper motors overheat, they were cross talking with the endstops, so somewhere on a long print, it would randomly go out of wack. If you guys have any suggestions on how to keep them from cross talking great, but I turned that option off in the firmware.
5. Once everything was battened down, I ran D42's calibration, just went ahead and started with the 6 factor. after the second iteration, was seeing awesome improvments. I did a test print after about 4 iterations, but as it didn't come out quite perfect, rechecked the numbers and I had forgotten to change one of the angles. Did 2 more iterations really trying to get the nozzle at the same distance each time I checked its height. So roughly after about 6-8 iterations, I checked a dry run of a 100mm diameter circle, at 0.15mm layer height, and it looked awesome. Actually running the new print right now and there is obviously still some difference in height, but way better than the .2mm off I was getting at the start of all this.
Two attached pictures, one of my rig, and another of the bad test print I did showing that the height was wrong because I messed up the angle.
Once again thanks a lot guys, would've taken me forever to figure out how to get this 3d printer to level out properly. Errors now I looking more like imperfections in the craft mirror that I am using as a build plate, and also the fact that I am not using a 3 screw orientation of the bed, it has multiple screws, so they might not all be perfectly fastening the bed. And kudos on that calibration calculator D42, it works very well when you put the right darn numbers in it!
-Nate
open |
download -
(232.7 KB)
open |
download -
(233.5 KB)
open |
download -
(364.4 KB)
