Beginner advice, Hardware serial ports April 03, 2016 11:50PM |
Re: Beginner advice, Hardware serial ports April 04, 2016 02:23AM |
Older as in Pre-Pentium? There is not a single 3D printer board i know of that directly supports RS232 and i have no idea why you would prefer it over USB. You are setting yourself up for a lot of hurt, extra work and utter frustration going this way. Printing from SD card is nothing fancy, it is a simple insurance against communication drops that ruin your hours long print.Quote
billy
As for the electronics side of things, I see alot of the printers connect to a computer via USB. I have an interest in using a much older computer with serial ports, is there any way to directly drive the printer via a serial port? I do not care about any fancy features on the printer side, things like printing from a sd card or fancy web interfaces, I just want to control the printer directly via a serial port.
Re: Beginner advice, Hardware serial ports April 04, 2016 06:44AM |
Admin Registered: 13 years ago Posts: 7,014 |
Re: Beginner advice, Hardware serial ports April 04, 2016 11:08AM |
Srek
Re: Beginner advice, Hardware serial ports April 04, 2016 01:27PM |
Re: Beginner advice, Hardware serial ports April 04, 2016 05:54PM |
Re: Beginner advice, Hardware serial ports April 04, 2016 09:51PM |
Re: Beginner advice, Hardware serial ports April 05, 2016 02:36PM |
Re: Beginner advice, Hardware serial ports April 05, 2016 02:43PM |
Re: Beginner advice, Hardware serial ports April 05, 2016 02:53PM |
Re: Beginner advice, Hardware serial ports April 05, 2016 03:01PM |
Re: Beginner advice, Hardware serial ports April 05, 2016 04:12PM |
Re: Beginner advice, Hardware serial ports April 08, 2016 04:15PM |
Re: Beginner advice, Hardware serial ports April 08, 2016 04:41PM |
What else does it tell us than to not use a heating element at 150% of it's rated voltage without any kind of control?
Re: Beginner advice, Hardware serial ports April 08, 2016 06:01PM |
Re: Beginner advice, Hardware serial ports April 09, 2016 07:31AM |
Keep in mind that the power consumption is always the result of the voltage and the resistance.Quote
atagunov
Thx for the info Srek. 25Wt heater cartridges?
