Change hysteresis value because of thermal runaway issue April 25, 2016 06:11AM |
Re: Change hysteresis value because of thermal runaway issue April 25, 2016 07:20AM |
Re: Change hysteresis value because of thermal runaway issue April 25, 2016 07:59AM |
Re: Change hysteresis value because of thermal runaway issue April 25, 2016 09:24AM |
MCcarman
I don't know if this is the issue but some readers may be interested to know:-
Some firmware has a protection feature that checks that after first reaching your target temperature, you reach it again within a certain time. Something like 30seconds. This is to protect for the thermistor coming of the hot part and under reading.
If the heater is cycling but not maintaining temperature then maybe the PID values are incorrect now you have fans. You can run a PID calibration with the fans on to get new values.
Origamib
Are you seeing thermal runaway on the heated bed, or the hot end? When I first installed 2x 50mm blower fans on mine, I would get thermal runaway of the hot end if I ran them at 100%. I found that I needed to run them at 50% and no higher. I recently insulated the hotend and this is no longer the case. ...
To be honest, I feel like upgrading my hardware would be a better, and overall safer alternative....
Re: Change hysteresis value because of thermal runaway issue April 25, 2016 09:43AM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 05:16AM |
20:07:47.070 : ok T:195.1 /195.0 B:66.6 /65.0 T0:195.1 /195.0 @:115 B@:0 20:07:50.384 : ok T:194.9 /195.0 B:66.4 /65.0 T0:194.9 /195.0 @:120 B@:0 20:07:53.742 : ok T:195.0 /195.0 B:65.9 /65.0 T0:195.0 /195.0 @:118 B@:0 20:07:56.370 : ok T:194.9 /195.0 B:65.6 /65.0 T0:194.9 /195.0 @:122 B@:0 20:07:59.543 : ok T:195.0 /195.0 B:65.1 /65.0 T0:195.0 /195.0 @:120 B@:0 20:08:02.478 : ok T:195.1 /195.0 B:64.7 /65.0 T0:195.1 /195.0 @:118 B@:0 20:08:06.155 : ok T:195.0 /195.0 B:64.3 /65.0 T0:195.0 /195.0 @:119 B@:127 20:08:08.714 : ok T:195.1 /195.0 B:64.5 /65.0 T0:195.1 /195.0 @:118 B@:127 20:08:12.557 : ok T:194.7 /195.0 B:65.5 /65.0 T0:194.7 /195.0 @:1 B@:127 20:08:15.568 : ok T:192.7 /195.0 B:66.2 /65.0 T0:192.7 /195.0 @:47 B@:0 20:08:18.813 : ok T:189.5 /195.0 B:66.7 /65.0 T0:189.5 /195.0 @:112 B@:0 20:08:22.384 : ok T:186.7 /195.0 B:66.7 /65.0 T0:186.7 /195.0 @:127 B@:0 20:08:23.903 : ok T:186.2 /195.0 B:66.6 /65.0 T0:186.2 /195.0 @:127 B@:0 20:08:27.226 : ok T:185.5 /195.0 B:66.2 /65.0 T0:185.5 /195.0 @:127 B@:0 20:08:30.499 : ok T:185.6 /195.0 B:65.7 /65.0 T0:185.6 /195.0 @:125 B@:0 20:08:33.202 : ok T:186.0 /195.0 B:65.3 /65.0 T0:186.0 /195.0 @:122 B@:0 20:08:36.631 : ok T:186.3 /195.0 B:64.8 /65.0 T0:186.3 /195.0 @:127 B@:0 20:08:39.919 : ok T:186.5 /195.0 B:64.3 /65.0 T0:186.5 /195.0 @:127 B@:127 20:08:43.689 : ok T:187.1 /195.0 B:64.3 /65.0 T0:187.1 /195.0 @:127 B@:127 20:08:45.957 : ok T:187.7 /195.0 B:64.8 /65.0 T0:187.7 /195.0 @:125 B@:127 20:08:48.419 : ok T:188.0 /195.0 B:65.3 /65.0 T0:188.0 /195.0 @:126 B@:127 20:08:51.990 : ok T:188.4 /195.0 B:66.1 /65.0 T0:188.4 /195.0 @:127 B@:0 20:08:55.927 : ok T:188.8 /195.0 B:66.6 /65.0 T0:188.8 /195.0 @:127 B@:0 20:08:57.234 : Error:Thermal Runaway, system stopped! Heater_ID: 0 20:08:57.234 : Errorrinter halted. kill() called!
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 06:02AM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 06:58AM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 08:14AM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 10:16AM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 10:46AM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 11:32AM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 12:00PM |
//=========================================================================== //============================= PID Settings ================================ //=========================================================================== // PID Tuning Guide here: [reprap.org] // Comment the following line to disable PID and enable bang-bang. #define PIDTEMP #define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current #define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 12:05PM |
Re: Change hysteresis value because of thermal runaway issue May 07, 2016 12:12PM |
Re: Change hysteresis value because of thermal runaway issue May 09, 2016 06:22AM |
Re: Change hysteresis value because of thermal runaway issue May 23, 2016 07:00AM |
Re: Change hysteresis value because of thermal runaway issue June 01, 2016 10:39AM |
