Dual drive gear extruder - interest and experience April 25, 2016 11:05AM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 12:05PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 12:10PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 12:20PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 12:43PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 01:10PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 03:24PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 03:32PM |
tomMulholland
That may be true in some cases, but consider that the newest generations of printers claim to reach speeds of 100, 200, or even 300 mm/s. I agree that print quality generally goes down as the speed is increased, but that precisely indicates that the extruder isn't functioning as desired. That's another reason to consider upgrading the extruder in some way.
Re: Dual drive gear extruder - interest and experience April 25, 2016 03:44PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 03:52PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 04:17PM |
tomMulholland
Hi Koko,
Thanks for your reply. I agree that the print quality is certainly affected by more things than just the extruder having trouble at high speeds. However, I would suggest that the problem is more real than people realize. For example, a colleague of mine did some extrusion tests with a temperature sweep. He used a FlashForge Creator 2, and sent the plain Gcode command to extrude at a given speed for 30 seconds, then measured the mass of the extrudate. You can then compare the expected mass (using motor turns and the filament diameter and density) to the extruded mass. The test was repeated at increasing temperatures.
If you look at those curves, you'll obviously see the importance of getting the right extrusion temperature. However, we also saw that higher speeds never actually got up to the same extruded mass as lower speeds, even at higher temperatures. This is surely related to the highest pressure you can achieve through your extruder / nozzle setup.
I'm not sure that a dual drive gear setup is the right answer - but I'm sure that the extruder is very important in determining the final part quality.
Re: Dual drive gear extruder - interest and experience April 25, 2016 06:00PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 07:05PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 11:35PM |
Re: Dual drive gear extruder - interest and experience April 25, 2016 11:37PM |
Re: Dual drive gear extruder - interest and experience April 26, 2016 09:27AM |
ggherbaz
Funny that someone opened this tread, I just finished designing one. It is printable and uses standard stuff. since I don't have access to milling equipment, the minor modifications needed will be done by hand....
I do think that extruder needs to be improved (not precisely my design...) but improvements needs to come as a whole and not to individual parts, you can have a great hotend but flimsy frame and you would not gain any quality in the printing, a great extruder but a crappy stepper will do the same.
Re: Dual drive gear extruder - interest and experience April 26, 2016 10:18AM |
Re: Dual drive gear extruder - interest and experience April 26, 2016 10:26AM |
DjDemonD
I can't see any problems with dual drive gear - I am presuming we're talking about both drive gears actually being driven rather than using one as an idler? It seems logical it would help to control filament more tightly. It is more complicated to build though.
If I can pick up on one point for clarification: My understanding with idler tension was that the filament grinds when the tension is too much, whereas the drive gear slips on the filament producing the click from the extruder if it is lighter and that this is recommended, assuming the motor current is not too high. Here we seem to be saying the idler should be very tight to prevent grinding and that the clicking is the motor skipping steps.
I don't have a preference but I have heard both versions and am interested to know which seems to the consensus view?
Re: Dual drive gear extruder - interest and experience April 26, 2016 11:13AM |
Re: Dual drive gear extruder - interest and experience April 26, 2016 01:08PM |
Re: Dual drive gear extruder - interest and experience April 26, 2016 01:17PM |
