Ideal hot end design for PLA April 29, 2016 01:27PM |
Re: Ideal hot end design for PLA April 29, 2016 01:35PM |
Re: Ideal hot end design for PLA April 29, 2016 01:46PM |
etfrench
E3D clones are <$10. How much cheaper do you need it?
Re: Ideal hot end design for PLA April 29, 2016 01:58PM |
Re: Ideal hot end design for PLA April 29, 2016 02:06PM |
Pawan
How would a heater block plus nozzle machined from one block of brass perform in comparison to aluminium block?
Wouldn't the PTFE liner spoil if put such close to the nozzle like E3D lite?
Re: Ideal hot end design for PLA April 29, 2016 02:12PM |
Re: Ideal hot end design for PLA April 29, 2016 02:16PM |
Pawan
Why do people choose brass for the nozzle? Aluminium alloys or SS do not serve the purpose?
Re: Ideal hot end design for PLA April 29, 2016 02:25PM |
Re: Ideal hot end design for PLA April 29, 2016 02:39PM |
Re: Ideal hot end design for PLA April 29, 2016 02:48PM |
leadinglights
I have always made my heater blocks out of copper but I wouldn't use it for a nozzle as it tends to be too grabby - trying to drill holes less than 0.5mm would break too many drills. Aluminium is slightly better but both brass and stainless steel are pretty well behaved by comparison.
Re: Ideal hot end design for PLA April 29, 2016 03:05PM |
Re: Ideal hot end design for PLA April 29, 2016 03:17PM |
Re: Ideal hot end design for PLA April 29, 2016 03:30PM |
Re: Ideal hot end design for PLA April 29, 2016 03:43PM |
Re: Ideal hot end design for PLA April 29, 2016 03:51PM |
Re: Ideal hot end design for PLA April 29, 2016 04:01PM |
Have you tried this? It goes against my experience.Quote
ggherbaz
For PLA only, you can get rid of the aluminum cooler fins and the stainless steel heat brake pipe.
If you properly insulate the top of the heater block or the whole thing better with porcelain, quartz glass or any other high temp material you can use a theaded press fitting on the PTFE tube and bolted straight into the heater block. The fitting will work as your thermal separator between the aluminum block and the PTFE liner and the insulator will prevent the heat from going up to the liner, the air passing through it will be sufficient to cool it of.
Re: Ideal hot end design for PLA April 29, 2016 04:03PM |
Re: Ideal hot end design for PLA April 29, 2016 04:09PM |
Re: Ideal hot end design for PLA May 01, 2016 06:52AM |
Re: Ideal hot end design for PLA May 01, 2016 07:20AM |
Re: Ideal hot end design for PLA May 01, 2016 07:02PM |
Re: Ideal hot end design for PLA May 01, 2016 07:18PM |
DjDemonD
Thermal conductivity of Tungsten is 173 W/(m·K) and it won't wear away very quickly at all, not sure it will turn on a lathe though.
I wonder if these guys will get this off the ground? [dddmaterial.com]
Re: Ideal hot end design for PLA May 01, 2016 07:22PM |
Re: Ideal hot end design for PLA May 02, 2016 12:12PM |
Re: Ideal hot end design for PLA May 02, 2016 12:30PM |
Ask E3DQuote
Pawan
Srek, E3D Lite has PTFE tube half way into the heater block and also touches the nozzle. Even with all gradient the temperature must definitely cross 220C. How come its working at that temperature?
Re: Ideal hot end design for PLA May 02, 2016 12:44PM |
Re: Ideal hot end design for PLA May 02, 2016 12:48PM |
Re: Ideal hot end design for PLA May 02, 2016 12:59PM |
Re: Ideal hot end design for PLA May 02, 2016 01:09PM |
Re: Ideal hot end design for PLA May 02, 2016 01:32PM |
