What is your experience with dual hotends? Are they worth the trouble? May 05, 2016 07:35PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 05, 2016 08:26PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 05, 2016 08:58PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 05, 2016 09:46PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 05, 2016 11:36PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 02:02AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 09:29AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 11:16AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 01:44PM |
dc42
- You really do need to design in a way of fine-adjusting the two nozzles to be at the same height.
[...] Reduce this effect by having the nozzles not too close together. A print cooling fan would probably help (my Ormerod doesn't have one).
Being able to remove one of the nozzles or tilt it out of the way for single-nozzle printing would be a bonus.
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 03:11PM |
realthor
Besides having a tilting system, isn't it a good way to ensure both heatingblocks are at the same level by having them connected to a common plate and have no worry with microadjustments each individual hotend?
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 03:35PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 04:00PM |
dc42
The long aluminium part connects the cold ends of both nozzles/heatbreaks to the heatsink. The nozzles have independent heater blocks.
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 04:35PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 04:55PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 05:04PM |
ggherbaz
he holes where the heat brake pipe goes have a locking bolt, the heat brake pipe is smooth
so to level both nozzles you just run the leveling sequence once in position you just loosen the locking bolts and use a filler gauge to adjust the nozzles to the correct distance from the bed.
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 05:27PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 05:30PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 06:03PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 06:31PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 06:57PM |
Me personally? None. I strongly considered building my new machine around a dual extruder design, mainly for the purpose of printing dissolvable support material. I ultimately decided against designing around it for a number of reasons. Mainly that to me the compromises needed to make dual extrusion happen would impact print quality with a single nozzle in ways I didn't want.Quote
JamesK
Koko76
Look at existing work. E3d is nice enough to publish drawings of already working designs.
Which designs did you have in mind?
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 07:30PM |
Theory is one thing, but actually adjusting something like this to work in the real world is a different matter. Tightening threads against each other is generally very very fiddly.
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 08:21PM |
Wire cutter can do all that and more. I have also used the wire to cut a kerf concentric with the bore, entering with a radial line. The concentric cut is maybe .05" (maybe 1.5mm max) from the bore, and might cover 40 degrees of the circle. You then use a set screw to press the "flap" against the part in the bore. I've also done opposing sets of these. Nice tight fit, and non marking on the shaft. Very compact too.Quote
JamesK
Yes, I agree, I don't think I'd want to try and use a lock nut to set the final height of a threaded throat. With a smooth throat I prefer a clamp to a set screw. I cut the slot with a slitting saw which seemed to work out ok. You need a reasonable kerf to give clearance for the clamp to close around the throat, especially if your tolerances run a bit on the generous side.
I remember a thread where someone had mounted the extruders (direct drive) on dovetails which allowed fine adjustment of the Z position. That seemed like a good approach.
Re: What is your experience with dual hotends? Are they worth the trouble? May 06, 2016 08:47PM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 05:59AM |
Koko76
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 07:22AM |
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 08:12AM |
Koko76
Not super useful though unless you have a wire cutter.
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 08:28AM |
These are things I have actually done, I don't need to suppose or speculate. What I described is a method in general to clamp objects into a bore with low runout, consistent surface contact, and non marking on the object being clamped. It would work well in the intended application, but most don't have the tools to make it work or would be willing to pay for someone to make it.Quote
realthor
Koko76
Sorry to be thick-headed but what part is the one you are cutting the flap into? The idea is pretty neat but the flap should also not be alu i suppose otherwise the set screw might eat into it.
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 08:43AM |
Koko76
realthor
Koko76
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 08:47AM |
Yes, I understand that. I understood it to start, which is why I showed a method that can do just that. Having never done this, or anything like it you suppose something will happen with the set screw. Having actually done it, it wasn't a concern of mine.Quote
realthor
Basically the heatsink (alu) would have to have this flap cut into.
Re: What is your experience with dual hotends? Are they worth the trouble? May 07, 2016 09:04AM |
Koko76
realthor
Koko76
