Planning to build a bigger Prusa i3, need help. May 07, 2016 09:03AM |
Re: Planning to build a bigger Prusa i3, need help. May 07, 2016 11:02AM |
Re: Planning to build a bigger Prusa i3, need help. May 07, 2016 11:59AM |
Re: Planning to build a bigger Prusa i3, need help. May 07, 2016 06:04PM |
stephenrc
[us.misumi-ec.com] Misumi will cut them to the length you need.
Openbeam on Amazon in fixed lengths
[openbuildspartstore.com] in fixed lengths
Re: Planning to build a bigger Prusa i3, need help. May 07, 2016 06:11PM |
the_digital_dentist
Having designed and built two printers with a 12" square bed moving in the Y axis I would not recommend doing it. If you want larger size, look at one of the designs where the bed moves in the Z axis.
There are multiple problems with moving a large bed in the Y axis:
Too much moving mass requires that you reduce acceleration which slows down printing, or spend a lot more on power supplies, external motor driver, and a big motor, or maybe all three.
If you care about print quality, throwing all that extra mass around requires a VERY rigid frame. 20 mm t-slot isn't going to cut it.
As parts get taller on such a design, they start to wobble when the Y axis reverses direction. That means the taller the part gets, the worse the print quality gets. That's especially true if the tall part has a small footprint on the bed plate....
Re: Planning to build a bigger Prusa i3, need help. May 07, 2016 06:43PM |
scarecrow2k6
Thanks for the suggestion, I was almost considering a delta style or cartesian printer but the only reason I wanted to stick with a Prusa i3 frame is because I know how it works. However, my main priority is quality over build volume. I will definitely put some more thought into it. Thanks!
