Are ABS fumes carcinogenic? May 07, 2016 07:15PM |
Re: Are ABS fumes carcinogenic? May 07, 2016 08:01PM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Are ABS fumes carcinogenic? May 09, 2016 11:01AM |
Re: Are ABS fumes carcinogenic? May 09, 2016 11:35AM |
Re: Are ABS fumes carcinogenic? May 09, 2016 11:49AM |
Re: Are ABS fumes carcinogenic? May 09, 2016 08:30PM |
Re: Are ABS fumes carcinogenic? May 09, 2016 09:23PM |
Re: Are ABS fumes carcinogenic? May 10, 2016 12:07AM |
Re: Are ABS fumes carcinogenic? May 10, 2016 08:37AM |
Re: Are ABS fumes carcinogenic? May 10, 2016 09:25AM |
foul_owl
Having the room be ventilated isn't enough?
You need filters also?
Re: Are ABS fumes carcinogenic? May 10, 2016 09:45AM |
Re: Are ABS fumes carcinogenic? May 10, 2016 10:34AM |
PRZ
This compact commercial unit (136x174x100- printclean scrubber) [3dprintclean.com]
do recirculation AND heat extraction (there is two fans).
It is adaptable to any enclosed printer/enclosure.
[edit] It extract heat via an exchanger, not by extracting air.
Very nice as an add-on on existing printers, but I think printers shall be designed from start with filtration in mind (this is what I have done for mines)
Re: Are ABS fumes carcinogenic? May 17, 2016 10:40PM |
Re: Are ABS fumes carcinogenic? May 18, 2016 03:46AM |
Re: Are ABS fumes carcinogenic? May 18, 2016 07:29AM |
