Re: Pololu geared DC motor 30g prototype extruder July 12, 2016 10:49AM |
rklauco
Well, for those that are lazy as me, I bought this.
It's a bit expensive, but there was nothing similar I could buy in the shops nearby.
I cut it using a normal saw and filed a "dimple" for the grab-screw of the MK8.
Re: Pololu geared DC motor 30g prototype extruder July 12, 2016 01:06PM |
nebbian
rklauco
You could have told me about that a couple of weeks ago!! Would have made life a lot easier. I cut a hole in that rod so that the mk8 set screw goes all the way through to the N20 shaft. Just an idea.
STLs and a better picture attached. Good luck, this design is a pre-alpha proof of concept. The bearings are MR105ZZ, which are 5mm ID, 10mm OD, 4mm width.
[attachment 81196 ScreenShot2016-07-12at22.48.png]
Re: Pololu geared DC motor 30g prototype extruder July 16, 2016 10:54AM |
Re: Pololu geared DC motor 30g prototype extruder July 16, 2016 11:05AM |
Re: Pololu geared DC motor 30g prototype extruder July 16, 2016 11:08AM |
Re: Pololu geared DC motor 30g prototype extruder July 17, 2016 10:05PM |
Re: Pololu geared DC motor 30g prototype extruder July 18, 2016 05:21AM |
Re: Pololu geared DC motor 30g prototype extruder July 26, 2016 05:37AM |
Re: Pololu geared DC motor 30g prototype extruder July 26, 2016 11:48AM |
Re: Pololu geared DC motor 30g prototype extruder July 27, 2016 12:54AM |
Re: Pololu geared DC motor 30g prototype extruder November 05, 2016 10:07PM |
Re: Pololu geared DC motor 30g prototype extruder November 06, 2016 03:39AM |
Re: Pololu geared DC motor 30g prototype extruder November 06, 2016 04:44AM |
Re: Pololu geared DC motor 30g prototype extruder November 06, 2016 01:29PM |
Re: Pololu geared DC motor 30g prototype extruder November 06, 2016 01:40PM |
Re: Pololu geared DC motor 30g prototype extruder November 07, 2016 07:32AM |
Re: Pololu geared DC motor 30g prototype extruder November 07, 2016 10:12AM |
Re: Pololu geared DC motor 30g prototype extruder November 07, 2016 04:37PM |
Congrats on getting so far. I had to put the project on the backburner for a while as personal life got a bit busier . If you can find a pair of beveled gears you could even run the motor from the back of the Chimera heatsink.Quote
matthock
Yeah, the ideal would really be a brushless motor with encoder, but they're pretty expensive.
My overall goal is lightweight dual direct drive with a Chimera, which will make the overall mechanism big enough that I was just going to stick a dedicated 40mm fan on top to cool the motors, at least for the time being. Maybe add one of the little sticky heat sinks for the stepper controllers on each motor.
Another idea under consideration is putting two of the faster motors on a single feed path. The MK8 hob is too small, but if I used a larger gear, it would be big enough I could pinch the filament between two of the motors at the same spot. You'd get the extra grip of two gears, and double your torque. The motors themselves are only ~10gm, so it would still be lightweight even doing it this way. A moderately larger motor would be more ideal, but the little Pololu motors are kind of nice since they have an off the shelf encoder solution - the next size of motor with an off the shelf encoder I can find is considerably larger (the Pololu 25mm motors, which weigh in at 95gm each)
Re: Pololu geared DC motor 30g prototype extruder November 08, 2016 04:29AM |
Re: Pololu geared DC motor 30g prototype extruder November 08, 2016 04:34AM |
Re: Pololu geared DC motor 30g prototype extruder November 08, 2016 05:14AM |
Re: Pololu geared DC motor 30g prototype extruder November 15, 2016 12:04AM |
Re: Pololu geared DC motor 30g prototype extruder November 18, 2016 12:20AM |
Re: Pololu geared DC motor 30g prototype extruder November 28, 2016 06:20AM |
Re: Pololu geared DC motor 30g prototype extruder November 29, 2016 07:07PM |
Re: Pololu geared DC motor 30g prototype extruder November 30, 2016 04:10AM |
Re: Pololu geared DC motor 30g prototype extruder November 30, 2016 04:20AM |
Re: Pololu geared DC motor 30g prototype extruder November 30, 2016 07:49AM |
Re: Pololu geared DC motor 30g prototype extruder November 30, 2016 08:01AM |
Re: Pololu geared DC motor 30g prototype extruder November 30, 2016 01:00PM |
