Re: Extruder Rate (request for crackpot ideas) July 24, 2008 12:28PM |
No offence taken. The call was for "crackpot" ideas .Quote
This wasn't intended to sound mean or confrontational, by the way.
I think you could do the medium sized parts. Instead of extruding an entire layer in one go, you would use it more like a inkjet printer (rather than the plotter style now used).Quote
It would only work with large parts, or multiple small identical parts, so it lacks a certain flexibility.
Yeah, that's the real killer I suppose. It wouldn't work on the current RepRap design, but might be for a type of spin off design. I'll let evolution handle that one .Quote
but you have to make a tougher and more rigid frame to bear the extra weight and the motors to push it around, and then deliver that much more power to the final device to keep those big motors going and all those extruders hot...
Anonymous User
Re: Extruder Rate (request for crackpot ideas) July 29, 2008 06:14AM |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 03:23AM |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 04:36AM |
It would be a simple way of seeing how fast your filament is being pushed into the mechanism
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 07:16AM |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 08:57AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 09:14AM |
Admin Registered: 16 years ago Posts: 13,900 |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 11:11AM |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 04:19PM |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 04:45PM |
Another problem with this idea is that the filament moves very slowly, so unless you have a very high resolution encoder you only get feedback relatively infrequently
It could work with a lower resolution encoder with a really small wheel (or perhaps one of those low-resolution encoders with a high mechanical advantage gear train that I described elsewhere).
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 04:51PM |
Re: Extruder Rate (request for crackpot ideas) August 01, 2008 11:54PM |
Re: Extruder Rate (request for crackpot ideas) August 02, 2008 03:52AM |
Sometimes it can be restarted by gripping the filament above the extruder with a pair of pliers and pushing it for a while until the stripped bit has passed through. Other times I have to strip down the extruder. It would always spoil the print as I don't cater for restarts in my software and I think the RepRap host can only pause between layers. However, once the spring tension is set correctly, it never happens so I don't find that it is a problem that needs a solution.Quote
Nophead, when you lose the thread on the filament, what do you have to do to recover extrusion - could you resume the print if you caught it quickly?
Re: Extruder Rate (request for crackpot ideas) August 02, 2008 10:48AM |
Re: Extruder Rate (request for crackpot ideas) August 02, 2008 11:55AM |
Sometimes the *eggs* I get at the market have some psrt of code printed onto them
Re: Extruder Rate (request for crackpot ideas) August 02, 2008 07:50PM |
Re: Extruder Rate (request for crackpot ideas) August 02, 2008 07:51PM |
Re: Extruder Rate (request for crackpot ideas) August 03, 2008 12:59PM |
joining in the crackpot spirit of the thread; with accurate temperature measurement it should be possible to detect loss of feed.
