Mendel X Axis Carriage - too much clearance from bearings to rod November 24, 2010 09:08PM |
Re: Mendel X Axis Carriage - too much clearance from bearings to rod November 24, 2010 09:33PM |
Re: Mendel X Axis Carriage - too much clearance from bearings to rod November 24, 2010 10:29PM |
Re: Mendel X Axis Carriage - too much clearance from bearings to rod November 25, 2010 06:06AM |
Admin Registered: 17 years ago Posts: 7,879 |
Tighten the middle two caps, keep the outer two pairs loose. When fully assembled use a piece of ΓΈ8 mm bar to set the distances between the bearings. Slide the bar between the bearings and tighten/slacken the outer two pairs of M4x40 caps to achieve a smooth, low resistance, running fit.
Re: Mendel X Axis Carriage - too much clearance from bearings to rod November 25, 2010 12:09PM |
