Designing an FDM extrusion head for Aluminum? July 11, 2016 01:37AM |
Re: Designing an FDM extrusion head for Aluminum? July 11, 2016 02:41AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Designing an FDM extrusion head for Aluminum? July 11, 2016 07:07PM |
VDX
... materials for FDM have a pretty big 'transition zone' between solid and fluid, where they are 'soft' enough to extrude, but won't flow away while layed down.
Metals have a really small transition zone, so not direkt usable for FDM ...
Re: Designing an FDM extrusion head for Aluminum? July 11, 2016 09:53PM |
Admin Registered: 13 years ago Posts: 730 |
mdowns8357
Has anyone tried anything remotely like this?
Read Before Posting - Technical Questions and Answers
25. Has anyone thought about 3D printing metal?
Yes. There are many established technologies for 3D printing metal parts, but most of these are beyond the reach of individual experimenters. There are many groups working on accessible low-cost technologies for 3D printing metal. Please see these working examples: A new approach to printing metals, Metal printing on a Lulzbot, Fused Deposition Modeling of Metals, Metal Delta RepRap v1.0, and these forum threads: Metal FDM thread, Metal-print Reprap, 3D Metal Printer Projects?, Induction Heated Nozzle, 3D Electroplating?, and these other resources: Metalbot.org, and MetalicaRap.
26. Can you extrude ordinary metal solder with a RepRap?
Yes. See First Reprapped circuit and Metal printing on a Lulzbot.
27. Can you extrude low melting point metal into grooves in a 3D printed plastic part?
Yes. See Multi-material freeform fabrication of active systems, First Reprapped circuit, and Syringe pump metal extruder.
mdowns8357
The build chamber could be purged with inert gas or a simple vacuum could be used to prevent the formation of oxide on the surface of the solidifying aluminum.
mdowns8357
For example, a tungsten extrusion head could be wound with copper coil and imparted with high current AC to heat the tungsten up
