How to translate gerber to STL ?
September 19, 2016 12:19PM
I want to use Repetier (Marlin firmware) to print the PCB. That's a given, not changeable.
Edited 2 time(s). Last edit at 09/19/2016 12:35PM by corcovado.
Re: How to translate gerber to STL ?
September 19, 2016 12:51PM
Can't you use one of the many gerber to gcode converters?
Edited 1 time(s). Last edit at 09/19/2016 12:52PM by stephenrc.
September 19, 2016 02:15PM
Ok, what are they? Maybe I can try ?
STL is generic, it doesn't involve the physics of your printer.
September 19, 2016 03:18PM
When I did a Google search on 'gerber to gcode' there was a lot of hits. The first page had a couple of free ones.
September 19, 2016 03:57PM
The "G" in g-code actually stands for Gerber. The basic commands in both types of files are pretty much the same, but Gerber programs have evolved with a lot of PCB specific commands, where as g-code programs have evolved with a lot of CNC, and now 3D printer specific commands.
September 19, 2016 07:48PM
Both Flatcam and pcb2gcode are for routers, doing isolation-routing.
Repetier is a 3d printer software, and my process is printing the solder mask.
G-code is always dependent on the tools used. STL instead is a representation of the object to be generated.
But then, how on earth I have missed the Inkscape. Solves my problems. Thanks.
Edited 2 time(s). Last edit at 09/19/2016 09:48PM by corcovado.
