My heated bed tried to self destruct. October 19, 2016 10:04PM |
Re: My heated bed tried to self destruct. October 20, 2016 12:19AM |
Re: My heated bed tried to self destruct. October 20, 2016 12:22AM |
Re: My heated bed tried to self destruct. October 20, 2016 05:06AM |
tmorris9
Bad connections cause resistance which causes heat then that causes worse connection which is more resistance and thus more heat. So this is caused by the connection starting to be bad and it snow balls from there. If you are going to use those screw terminals be sure to check them for tightness every once in awhile. A little loos or a little corrosion and this is what you end up with.
Re: My heated bed tried to self destruct. October 20, 2016 05:40AM |
Re: My heated bed tried to self destruct. October 20, 2016 11:52AM |
Re: My heated bed tried to self destruct. October 20, 2016 01:30PM |
Re: My heated bed tried to self destruct. October 20, 2016 01:47PM |
Re: My heated bed tried to self destruct. October 20, 2016 01:59PM |
Um, well my sugestion wont work as the boards are only 12v.....Quote
Dalius98
Well in my case, I am using a 220V AC 800W heater, which came with ~30cm long leads and I need some way of extending them. So far I was under the impression that these screw terminals are a really good solution... guess not...
Re: My heated bed tried to self destruct. October 20, 2016 03:19PM |
Re: My heated bed tried to self destruct. October 20, 2016 03:21PM |
Dalius98
Re: My heated bed tried to self destruct. October 20, 2016 03:42PM |
Re: My heated bed tried to self destruct. October 20, 2016 07:16PM |
Re: My heated bed tried to self destruct. October 20, 2016 10:57PM |
