Delta printer misalignment October 30, 2016 06:57AM |
Re: Delta printer misalignment October 30, 2016 12:17PM |
Re: Delta printer misalignment October 30, 2016 01:21PM |
Re: Delta printer misalignment November 01, 2016 05:19AM |
Re: Delta printer misalignment November 01, 2016 04:26PM |
ohfurryone
You need to re-adjust the Smooth_Delta_Rod_Offset. It is an arbitrary value that doesn't properly apply to all types of delta so it has to be found another way.
A quick method I use:
- Make sure your end-stops are fairly accurate by measuring from the base of the printer.
- Place a piece of masking tape on one side of your bed along the X axis from center to edge.
- Lower nozzle to the bed and scribble around it with a pencil, raise and find center of circle left behind.
- Find an accurate ruler, square, fabric measuring tape ect. and mark out 20, 40, 60 and 80mm from center to edge.
- Move the nozzle along the bed on the X axis and see if it scales to 60-80mm properly, you should find it will be out by 1/2mm or so.
Change Smooth_Delta_Rod_Offset up and down to compensate. You eventually want to adjust it in .25mm intervals, until the nozzle ends up bang on at 80mm. The reason why you need multiple measurements is if one is 1/2mm wrong, it will stick out and you can re-mark it.
Re: Delta printer misalignment November 02, 2016 03:52PM |
LarsT81
What I did was marking a point about center of plate and then measure the distance for each carrier and then averaging the distances. In theory this should give the correct distance as far as I understand.
Re: Delta printer misalignment November 02, 2016 03:59PM |
