Hi Adam,
I've developed a Piezo-driven pastedispenser with a common mechanical setup, ArduinoDue+RADDS for electronics, Marlin4Due firmware and heavy modified Pronterface for controlling/printing.
Posted here (in German) the progress with some images and videos - especially on the next pages - [
forums.reprap.org] )
The valves are controlled by TTL-pulses (up to 3kHz max.) and the dispensed volume is defined either by pulses/pad (many droplets on the same position) or by pulses/mm for lines with varying width. The volume per drop can be set with the controller too, but I'm using the pulses/pad for this ...
The controller needs "inverted" 5V pulses with min 5µs pulse width, while the ArduinoDue gives 0,5µs long pulses with 3,3V -- so I've fed the extruder motor step pin through a 74HCT123 "monoflop" to define a longer pulse width and set it to 5V.
Wouldn't be a problem to define longer (or "endless") pulses with the first pulse of a line and reset the output with line end, but then you'll need another analogue pin to define the volume rate per time ... the pulse-driven volumetric output is simpler and conform to common FDM-3D-printing ...
Edited 1 time(s). Last edit at 11/10/2016 12:08PM by VDX.
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [
reprap.org] -- Deutsche Facebook-Gruppe - [
www.facebook.com]
Call for the project "garbage-free seas" - [
reprap.org]
