Help on selecting linear bearings December 03, 2016 09:14AM |
Re: Help on selecting linear bearings December 03, 2016 10:11AM |
Re: Help on selecting linear bearings December 03, 2016 10:27AM |
Re: Help on selecting linear bearings December 03, 2016 10:36AM |
Re: Help on selecting linear bearings December 03, 2016 10:39AM |
the_digital_dentist
The motors and fans will make more noise than the bearings.
Re: Help on selecting linear bearings December 03, 2016 03:55PM |
Re: Help on selecting linear bearings December 03, 2016 04:14PM |
Re: Help on selecting linear bearings December 03, 2016 04:47PM |
Re: Help on selecting linear bearings December 03, 2016 09:49PM |
Re: Help on selecting linear bearings December 04, 2016 11:12AM |
Joachim
Icefire: Thanks for your reply!
Well, one advantage of watercooling would be that I could use it together with a heated chamber. But I'm not set yet and will take your solution into consideration (Maybe upgrading to water cooling at a later point?)
As I already have some silent 50mm fans, I will start with them, but your link is great (thinking about ordering some of them for another project - they are normally much more expensive! )
Decoupling the frame from the surface sounds better than decoupling the motors, it also removes complexity from the machine - thats always nice.
I'm not even at the driver-selecting point, but if you have a good proposal for drivers I will look at it (what would you recommend over the DRV8825 if I have no favorite?).
What do you think about the rails? Would you still prefer normal supported linear guides with blocks over plastic bushings?
Re: Help on selecting linear bearings December 04, 2016 11:27AM |
Re: Help on selecting linear bearings December 04, 2016 12:39PM |
Joachim
Re: Help on selecting linear bearings December 07, 2016 02:08PM |
Re: Help on selecting linear bearings December 10, 2016 11:36AM |
