Heated relay overheating December 07, 2016 11:02AM |
Re: Heated relay overheating December 07, 2016 01:52PM |
Re: Heated relay overheating December 07, 2016 03:43PM |
Re: Heated relay overheating December 07, 2016 06:26PM |
Re: Heated relay overheating December 07, 2016 06:55PM |
elwood127
If you switch to an SSR make sure you get the matching heatsink. I use a 40 x 40 x 20mm fan hooked up to the control side of the SSR and have had no overheating issues.
[attachment 87100 DSC00939.jpg]
Re: Heated relay overheating December 07, 2016 07:56PM |
dc42
A mechanical relay is a poor solution for driving a bed heater. Either use electronics that is capable of driving the bed heater directly - which for a 12" printer probably means using 24V power - or use a solid state relay (SSR). For SSR recommendations, see [duet3d.com]. That page was written for Duet electronics, but the SSR choice applies to any printer electronics.
Re: Heated relay overheating December 07, 2016 08:02PM |
Re: Heated relay overheating December 08, 2016 03:54AM |
Re: Heated relay overheating December 08, 2016 08:51AM |
Re: Heated relay overheating December 08, 2016 10:08AM |
Re: Heated relay overheating December 08, 2016 09:07PM |
DjDemonD
Something odd must be going on then, I run 12.5amps through a 40amp relay, never had any issue from the relay, slightly melted fuse holder at one point. Without more information I have nothing more to add.
Re: Heated relay overheating December 09, 2016 06:52AM |
Re: Heated relay overheating December 09, 2016 08:07AM |
Re: Heated relay overheating December 10, 2016 07:14AM |
Re: Heated relay overheating December 10, 2016 07:28AM |
Re: Heated relay overheating December 11, 2016 11:15AM |
Re: Heated relay overheating December 11, 2016 11:26AM |
Re: Heated relay overheating December 11, 2016 01:56PM |
shsims
would this be overkill ,,,,,Baomain SSR-100DD 100A DC-DC 100A Solid State Relay Module 3-32VDC/5-80VDC + Heat Sink only 18.00 US
Re: Heated relay overheating December 17, 2016 07:40PM |
Re: Heated relay overheating December 17, 2016 09:19PM |
Re: Heated relay overheating December 20, 2016 08:53PM |
Re: Heated relay overheating December 22, 2016 02:50PM |
Re: Heated relay overheating December 22, 2016 03:58PM |
Re: Heated relay overheating December 22, 2016 04:22PM |
Re: Heated relay overheating December 22, 2016 04:55PM |
Re: Heated relay overheating December 22, 2016 05:41PM |
Re: Heated relay overheating December 22, 2016 06:39PM |
Re: Heated relay overheating December 22, 2016 06:42PM |
Re: Heated relay overheating December 22, 2016 06:47PM |
Re: Heated relay overheating December 22, 2016 06:50PM |
