Invert Inductive Sensor for different hotends December 22, 2016 05:07PM |
Re: Invert Inductive Sensor for different hotends December 23, 2016 06:11AM |
Re: Invert Inductive Sensor for different hotends December 23, 2016 09:52AM |
Re: Invert Inductive Sensor for different hotends December 23, 2016 10:45AM |
Re: Invert Inductive Sensor for different hotends December 23, 2016 11:17AM |
Re: Invert Inductive Sensor for different hotends December 23, 2016 01:32PM |
Re: Invert Inductive Sensor for different hotends December 23, 2016 01:47PM |
DjDemonD
If you are not using the sensor for auto levelling and you are essentially using it as a z endstop, why not just use a regular z endstop?
Re: Invert Inductive Sensor for different hotends December 23, 2016 06:41PM |
DaveOB
I considered a mechanical switch that the nozzle could push, but if there is any filament hanging below the nozzle from the previous print, then that would affect the function.
The problem is that both hot ends fit in the same extruder, and the volcano is a longer / taller hotend than the e3dv6.
So each time I swap, I am having to adjust the Z end stop by around 10mm.
I am looking for the easiest solution where I do not need to keep changing the end stop.
Re: Invert Inductive Sensor for different hotends December 24, 2016 09:02AM |
DaveOB
