Do sharper nozzles handle overhangs better? December 27, 2016 07:44PM |
Re: Do sharper nozzles handle overhangs better? December 28, 2016 02:20AM |
Re: Do sharper nozzles handle overhangs better? December 28, 2016 04:43AM |
Re: Do sharper nozzles handle overhangs better? December 28, 2016 07:20AM |
Re: Do sharper nozzles handle overhangs better? December 29, 2016 02:46AM |
Re: Do sharper nozzles handle overhangs better? December 29, 2016 05:25AM |
Re: Do sharper nozzles handle overhangs better? December 29, 2016 10:26AM |
Re: Do sharper nozzles handle overhangs better? December 29, 2016 02:29PM |
Re: Do sharper nozzles handle overhangs better? December 29, 2016 02:56PM |
If the filament stretches you get unconnected strands. Curling filament is an indicator for an uneven or damaged nozzle opening.Quote
Kurzaa
My filament will occasionally curl out of the nozzle when extruding in mid-air, thought it was just a thing, never considered the shape of the nozzle (using an E3D) to be a factor. However when bridging, I assume you want to "stretch" the filament out over the bridge, pulling it into a straight line. So I would assume if it is curling on you, perhaps you need to speed up your bridges?
Re: Do sharper nozzles handle overhangs better? December 29, 2016 03:28PM |
Re: Do sharper nozzles handle overhangs better? December 29, 2016 05:11PM |
