LCD dial not showing menu when pressed...
Posted by saintofinternet
January 05, 2017 10:55PM
hi,
today i flashed the marlin latest release for the first time on my first build of prusa i3 printer.
when i press the dial... it shows nothing... just stays on the main screen.
also the X , Y , and Z axis on the LCD display are alternatively flashing a "?" (question mark) symbol...........
Re: LCD dial not showing menu when pressed...
January 06, 2017 04:03AM
Reading all your previous post, you must have gotten the worst printer ever.
Everything seems to be blown up, wired wrong or is non functional... sad smiley
If I were you, I'd ask the seller for a full replacement.
Edited 1 time(s). Last edit at 01/06/2017 04:04AM by o_lampe.
January 06, 2017 06:24AM
actually the firmware the supplier has provided has fully functional LCD menu.... but
i tried with another arduino just to learn everything.... using the downloadable Marlin firmware... but that is giving problem....
January 06, 2017 07:02AM
The X Y Z will flash ? until the axis have been homed ,then they should show axis position.
