MINIMUM PRINTING SPEED January 11, 2017 09:07AM |
Re: MINIMUM PRINTING SPEED January 11, 2017 09:26AM |
Re: MINIMUM PRINTING SPEED January 11, 2017 09:31AM |
Re: MINIMUM PRINTING SPEED January 11, 2017 09:35AM |
Re: MINIMUM PRINTING SPEED January 11, 2017 09:44AM |
Re: MINIMUM PRINTING SPEED January 11, 2017 10:10AM |
Re: MINIMUM PRINTING SPEED January 11, 2017 10:41AM |
Re: MINIMUM PRINTING SPEED January 11, 2017 12:23PM |
Re: MINIMUM PRINTING SPEED January 11, 2017 02:14PM |
Origamib
I would be tempted to say there are other methods to achieve the result you want, without using insanely slow speeds. If your material is so viscous, are you even achieving inter layer bonding? Upping the temperature will in most cases (I cant think of one where it doesn't, unless of course you go so high you carbonize the material...) increase flow, letting you print faster and giving better layer bonding.
Re: MINIMUM PRINTING SPEED January 11, 2017 05:00PM |
Origamib
Re: MINIMUM PRINTING SPEED January 11, 2017 11:54PM |
Re: MINIMUM PRINTING SPEED January 12, 2017 04:02AM |
Re: MINIMUM PRINTING SPEED January 12, 2017 08:28AM |
Re: MINIMUM PRINTING SPEED January 12, 2017 09:12PM |
Re: MINIMUM PRINTING SPEED January 13, 2017 08:25AM |
Re: MINIMUM PRINTING SPEED January 13, 2017 08:59AM |
Floyd
Not sure what slicer software your using but it was real easy to set to 1mm/sec in Cura. From there I used the LCD knob to lower the speed even more.
Re: MINIMUM PRINTING SPEED January 13, 2017 09:32AM |
Re: MINIMUM PRINTING SPEED January 13, 2017 09:43AM |
Floyd
In Cura there was maybe 4-6 speed settings that I had to set to 1mm/sec.
Also you could just manually edit the code to drop the feedrate then run it.
